ad pot fastest response!
Results 1 to 13 of 13
    Alaskanphoenix's Avatar
    Alaskanphoenix Guest
    You are right!
    I use a 16f88 to control 7 pots connected at the 7 ad pin and 3 bottons, one to calibrate the pots and the other to send midi control change messages.The pots, when rotated, must send midi continuos change message through the ausart.The ausart is configured comply with the midi protocol(31250 baud).this is an example of the midi message:
    define osc 20
    define HSER_TXSTA 20h ' enable TX register
    DEFINE HSER_RCSTA 90h ' enable RX register
    define HSER_BAUD 31250 ' midi baud rate
    for j = 0 to 6
    RESULT[J] = NEW[j]
    ADCON0 = %11000001 + (J*8) 'SET A/D rC + A/D = ON
    PAUSEus 10 'PAUSE 10uS FOR CHANNEL SETUP
    ADCON0.2 = 1 'SET GO/DONE-BIT + START CONVERSION
    PAUSEus 10 'PAUSE 10uS FOR CONVERSION
    RESULT[J] = ADRES
    RESULT[J] = RESULT[J] >> 1
    'read j, NEW[j]
    if RESULT[J] <> NEW[j] then
    'write j, NEW[j]
    hserout [$b0, j, RESULT[J]]
    next j
    goto loop
    RESULT is the value of the controller comply with midi,it must be 0-127
    $bo is the statusbyte, j the channel.
    The problem is that the program sends midi messages continuously,i want it sends midi only when the pot is rotated, sending all the values untill i stop to rotate!
    Also i want to limit the range of the pot with the calibrate button,when i first press the button i set the min value to 0, then i rotate the pot to set another value corresponding to 127 pressing the button.
    sounds familiar with tons of recent MIDI controller i built here.
    OK let's try to do some rough explanation
    1.i want it sends midi only when the pot is rotated, sending all the values untill i stop to rotate!
    what i suggest, is to store every POT valu in an array variable or different variable for each pot. You'll read ALL pot in a continuous loop then compare the result you have with the according variable or Array Index. Sure you'll have to insert a error percentage as the AD result may vary a little bit.
    Once you have a different value you send it on the MIDI line.
    2. i want to limit the range of the pot with the calibrate button,when i first press the button i set the min value to 0, then i rotate the pot to set another value corresponding to 127 pressing the button.
    Perfect situation to introduce some POWER-UP check up. To make things clear figure the following. When you power up your system, you check if one (or more) specific push button are press, if so, you jump to the calibration routine
    In the calibration routine, a LCD or XYZ LED will prompt for a start point on POTx, you place the pot to the according position then you press on a button. Once it's done same thing apply to the end point. Same for all POTs. Once it's done, it's up to you what you'll do as calibration confirmation.
    Calibration must be store in a external EEPROM (or internal if available). When you boot your system, it just read the calibation and store them in some variables.
    Hope this help
    Thank you mister_e!
    It's time to experiment!
    I'll try some of your suggestions
    Bye
    moyejw's Avatar
    moyejw Guest
    Alaskanphoenix, I'm not familiar with pbp syntax but try something like this IF...THEN statement in place of yours--
    IF RESULT[J] = ADRES THEN NoCHANGE
    CHANGE RESULT[J] = ADRES
    /calculate mididata :see below
    /send mididata
    NoCHANGE NEXT J
    To convert your AD input to proportional value between 0 and 127---
    /this is simiiar to Farenheit to Centigrade temp conversion
    You need these values from when you calibrate your pots. JCALLOW, JCALHI
    are values received @ CALIBRATE BUTTON1. BUTTON2
    JMIDIVALUE=127(ADRES - JCALLOW)/(JCALHI - JCALLOW)
    moyejw's Avatar
    moyejw Guest
    /send mididata
    NoCHANGE NEXT J
    blainecf's Avatar
    blainecf Guest
    Cool One more method (unless you're an octopus):
    If you make the assumption that only one pot at a time is changing (unless you're an octopus and have 8 hands on 7 pots), you could do this:
    [Pseudocode]
    1. read one pot
    2. compare to previous reading (see above threads)
    3. if a pot changes
    3a. Act on the change
    3b. (now for the assumption) Instead of advancing on to the next pot, decrement your pot pointer so that the same pot will be read again (which will cancel out step #4, below)
    4. increment your pot pointer
    5. loop to #1
    Why? If you assume one hand on a pot, once you start changing, probability suggests that you'll continue changing that pot. Assuming that that one pot is still changing, and therefore, re-reading, you'll save time NOT READING 6 other pots that, in all likelihood, are not changing!
  1. Using the Pot command.
    By timseven in forum mel PIC BASIC Pro
    Last Post: - 17th August 2009, 21:23
  2. A/D, Pot, Input, A,B So lost now....
    By Helmutt in forum mel PIC BASIC Pro
    Last Post: - 9th March 2008, 23:23
  3. "quantizing" AD values
    By dar303 in forum mel PIC BASIC Pro
    Last Post: - 21st February 2007, 22:49
  4. Replies: 4
    Last Post: - 24th January 2007, 23:20
  5. pot controlled pwm -- help
    Last Post: - 29th January 2006, 13:29
