16f628a Hpwm-stop??
Results 1 to 5 of 5
    Caddydan's Avatar
    Caddydan Guest
    Red face 16f628a Hpwm-stop??
    I am using the 16f628a as a lamp dimmer for my mountain bike light. I can change the duty cycle of the hpwm but can't get the pin to just stop without setting the on time to 0-HPWM just runs and runs and.... Any ideas??
    Thanx Dan
    Wink 0% equals ... Low output
    just have a ZERO for PWM value ...
    CCP1CON = 0 Disables the PWM unit ... think to re-Enable it somewhere.
    AND it's probably safe to set the pin low after that... Maybe.
    Caddydan's Avatar
    Caddydan Guest
    Thumbs up
    I know setting on time to zero turns things off but I wanted to use the same pin for flashing the light and hpwm does not run slow enough. CCP1CON = 0
    worked great.
    Thanx for helping us newbies out.
    Dan
    This is why forums exist dude!
    Good luck!
    PS: keep it for you... i learn almost everything here by reading other posts and solutions, datasheet, do experiments and, when possible, helping others. Don't give up.. oh no, don't give up.
  1. need help on hpwm
    By helmut in forum mel PIC BASIC Pro
    Last Post: - 28th August 2007, 15:49
  2. HPWM of the port of two HPWM
    By ja2rqk in forum mel PIC BASIC Pro
    Last Post: - 25th April 2007, 15:05
  3. sound command & music
    By trying in forum mel PIC BASIC Pro
    Last Post: - 26th May 2006, 14:14
  4. 3 HPWM channels
    Last Post: - 4th April 2006, 02:43
  5. HPWM and 16F628A
    By Michael in forum mel PIC BASIC Pro
    Last Post: - 14th February 2006, 14:27
