4x3 keypad
Results 1 to 10 of 10
Thread: 4x3 keypad
    Jan 2006
    mr-e,
    thanks for the code, it looks very simple and easy to use, however, it must be a little too complicated for me because I am getting nowhere. Maybe you can find something stupid and obvious, but I cant find it.
    here is your code modified to my use
    '* Name : UNTITLED.BAS *
    '* Notice : Copyright (c) 2006 [select VIEW...EDITOR OPTIONS] *
    '* : All Rights Reserved *
    '* Date : 4/13/2006 *
    '* Version : 1.0 *
    '* Notes : *
    TRISB = %10000000
    ADCON1 = %11111111 'all ports digital
    INCLUDE "KeyPad.bas"
    ' Hardware connection
    DEFINE KEYPAD_ROW 4 ' 8 row
    define KEYPAD_ROW_PORT PORTA ' on PORTA
    DEFINE KEYPAD_ROW_BIT 0 ' <3:0>
    DEFINE KEYPAD_COL 3 ' 3 col
    DEFINE KEYPAD_COL_PORT PORTC ' on PORTC
    DEFINE KEYPAD_COL_BIT 4 ' <7:4>
    DEFINE KEYPAD_DEBOUNCEMS 200 ' debounce delay = 200 mSec
    define KEYPAD_AUTOREPEAT 0 ' use auto-repeat
    ' Serial Communication definition
    DEFINE LCD_DREG PORTB ' Set LCD Data port
    DEFINE LCD_DBIT 0 ' Set starting Data bit (0)
    DEFINE LCD_RSREG PORTB ' Set LCD Register Select port
    DEFINE LCD_RSBIT 4 ' Set LCD Register Select bit
    DEFINE LCD_EREG PORTB ' Set LCD Enable port
    DEFINE LCD_EBIT 6 ' Set LCD Enable bit
    DEFINE LCD_BITS 4 ' Set LCD bus size (4 or 8 bits)
    DEFINE LCD_LINES 2 ' Set number of lines on LCD
    DEFINE LCD_COMMANDUS 2000 ' Set command delay time in us
    DEFINE LCD_DATAUS 50 ' Set data delay time in us
    ' Variables definition
    myvar var byte
    ' ---------------------------------[Program Start]----------------------------------------------
    lcdout $fe, 1, "Hello"
    start:
    @ READKEYPAD _myvar
    lcdout $fe, 1, "Key=", DEC myvar
    goto start
    I threw the "Hello" in there just to test that it programmed correctly and the LCD is functioning.
    When I press any button, it still just says hello. So something in the button config aint workin.
    I am using Microcode studio 2.3, PBP2.46, and MPASM.
    I have my rows hooked up with 4.7k pullup resistors as you stated and they are pinned to RC4-6. I also have the columns hooked up with 4.7k series resistors (too high a value?) to RA0-3.
    thanks again for posting your code.
    In fact you MUST use some low value for column, let's say 100-300 ohms. 4.7K is way too high. The PIC don't detect the LOW level signal. In best case the LOW level will be 2.5 volts... too high for a LOW level signal Refer tosection 18.4 of your datasheet for that.
    You can even remove the column resistor and plug it directly... it will work but it's not really recommended.
    Another thing, you must disable analog comparator too on PORTA
    ADCON1=$0F    ' Disable AD converters
    CMCON =7      ' Disable analog comparator
    About now?
    PS: you can remove the DEFINE KEYPAD_AUTOREPEAT line. If you don't write it, the program will set it to off for you. This refer to that section of the include file
                          @ ifndef KEYPAD_AUTOREPEAT           '       If AutoRepeat is not DEFINE
                                   repeat
                                       Gosub readcol           '           Wait until
                                       until KeyTemp=keymask   '               Key is released
                                   @ endif
    Jan 2006
    Thanks very much steve.
    I have it running and the keys are being read. I tried using low value resistors on the columns but it didnt work, but low value resistors on the rows and it started reading.
    One problem though, The first two rows are working perfect, but the second two rows will change values every time I press the button.
    these columns.
    The two affected rows are connected to the VREF pins on PORTA, is there a disable config for VREF? or is it default disabled?
    one more question also while your peeking at this thread. is there a way to make the auto repeat work only on 2 buttons? Two buttons on my kepad are +- adjustments and all the others are command buttons. It would be great to make the +- buttons autorepeat.
    Did you modify your code and include those lines at the top?
    Comparator voltage reference is suppose to be set to off by default if you refer to the CVRCON POR. AND when you set ADCON1 to 0F, you set VREF- to Vss, VREF+ to VDD... so i can't understand why it doesn't work.
    The first thing spring to mind is to set the AUTOREPEAT to ON then read the MyVar value and if it's not one of your two keys... redo the keypad scan until it change.
    PS: you're right, i did a mistake, low value resistor must be on ROWs, not colums... DOH!
    Jan 2006
    we have operation. thanks very much steve.
    it was the ADCON1 register. Do you have any resources to better explain registers and their settings. when I read about them in datasheets is all just a totally different language to me.
    I have yet to implement the autorepeat. Ill post again with its results
    Jan 2006
    I got my desired repeat with a simple loop comand.
    thanks for all your help steve, its been invaluable.
    If you feel so inclined, would you mind looking over my code and schematic to check for any changes that could be made for efficiency and design?
    thanks
    -brian
    You're welcome! Great to know it's working fine now.
    No problem, post your stuff here. i'll post my own comments, i hope other will also do it too.
    Sorry, i don't see any other reference. Sure sometimes datasheet are just Chinese to me (or greek depending of your local expression) but by using the trying/debuging/understanding method you'll never find any better reference. The first time is always the hardest... once you hit the wall and bang your head on your keyboard few times, you can't forget it. This is probably why i choosed this picture for my avatar <img src="http://www.picbasic.co.uk/forum/member.php?u=580">
  1. 4x4 keypad Help
    By aaliyah1 in forum mel PIC BASIC Pro
    Last Post: - 5th October 2010, 17:34
  2. keypad 4x3
    By jonas2 in forum mel PIC BASIC Pro
    Last Post: - 15th July 2009, 07:34
  3. 4x3 keypad and an LCD.. need help.
    By taisen83 in forum mel PIC BASIC Pro
    Last Post: - 6th January 2009, 10:34
  4. Keypad input test
    By Kalind in forum mel PIC BASIC Pro
    Last Post: - 8th October 2008, 05:00
  5. Need help in matrix keypad coding
    By rano_zen06 in forum mel PIC BASIC Pro
    Last Post: - 24th May 2008, 14:16
