Acin command on 16F876, unable to read on AN1
Results 1 to 3 of 3
    krapoto's Avatar
    krapoto Guest
    Default Acin command on 16F876, unable to read on AN1
    Hello,
    I try to use the Adcin function on a 16F876 device, it's work nice only on port AN0 and I can't read on Port AN1, AN2, AN3... ?
    I use PBP 2.42a .
    Thanks for your help or Idea.
    My code :
    DEFINE OSC 20
    DEFINE ADC_BITS 10
    DEFINE ADC_CLOCK 3
    DEFINE ADC_SAMPLEUS 10
    TRISA = %11111111 ' Set PORTA to all input
    ADCON1 = %10000000 ' Right justify
    ADIN VAR PORTA.1 ' work nice with PORTA.0 !!!
    ADVAL VAR WORD
    ADCIN ADIN,ADVAL
    adval = (adval */ 500)>>2
    First you must write the channel numer you want to read instead of the PIN name
    ADCIN 0, Avar
    ADCIN 1, AnotherVar
    krapoto's Avatar
    krapoto Guest
    Thumbs up Adcin
    Hi Steve,
    Thank you for your advice, it's work fine now !
    Charles
    Quote Originally Posted by mister_e
    ADCIN 0, Avar
    ADCIN 1, AnotherVar
  1. Cleaning up code
    Last Post: - 2nd December 2009, 07:14
  2. SEROUT WORD variable problem
    Last Post: - 19th April 2009, 11:20
  3. Write and Read from eeprom
    Last Post: - 9th June 2007, 14:56
  4. Changing declared variables names on the fly
    Last Post: - 16th December 2006, 06:34
  5. Problems with 16F876 on interrupts an WRITE / READ
    By BigWumpus in forum mel PIC BASIC Pro
    Last Post: - 20th December 2005, 14:38
