serout and serin problem
Results 1 to 4 of 4
    Default serin and serout over RF
    Sorry, I just realized that your serouts are exclusive to each associated transmitter device.... kind of hard to know what's going to happen without knowing what lines are being used as busy/handshaking lines...
    nicolelawsc's Avatar
    nicolelawsc Guest
    Unhappy any suggestion?
    do u hv any suggetion to solve this problem?actually i hv 3 pair of transmitter and only one receiver.each of the transmitter with a identify code for receiver to determine the code sent from which transmitter.as i post the code above. Below shows the concept of my code,can u please give me some comment whether my code have any problem.i try many ways already but still do not know why my receiver can not receive data.
    serout PORTB.0,N9600,["A",1]--transmitter 1 with the identify code "1"
    serout PORTB.0,N9600,["A",2] --transmitter 2 with the identify code "2"
    serout PORTB.0,N9600,["A",3]--transmitter 3 with the identify code "3"
    and at the receiver the command is--serin PORTB.2,N9600,["A"],rx
    what i mean here is each of the transmitter hv the password "A" and the number at the back of "A " represent the identify code.then at the receiver if the rx it receive is "1", mean receive from transmitter 1.
    rx is "2" mean receive from transmitter 2 and rx "3"mean receive from transmitter 3.
    is it my code got error?any correction for me?
    actually at the receiver pin 3 is detect pin.at the datasheet it stated may used to derive a carrier detect to enable external circuit when a signal is being received.if unused connect a 10k ohm resistor to Vcc.
    so i jz connect it directly with 10Kohm resistor to Vcc.Do u think this pin can help me in this situation?if yes,can u please gv me some guide line?
    another problem is i am dealing with a math problem. the equation as below:
    ---theta s= actan (Y2/X2)- theta 2-----
    Y2, X2 and theta 2 are known,i need to find the theta s but by using pic basic pro, i do not know how to deal with "actan"
    Dec 2003
    Wichita KS
    Hello,
    I don't fully understand what you are trying to do, or what your schematic is looking like but I would try the following:
    1. You said it only works on Transmitter 1.. That is case statement 1.
    For this, I would drop the case statement and us "IF" "Then" statements... see if that makes a difference.
    2. You have extremley long pauses after each recieve... the first 2 have 2 second pauses, the last one has 1 second pause.... Is this too long of a pause??? Is it necessary?
    3. Baudrate... 9000 Try something like 300 first.
    Dwayne
    Ability to Fly:
    Pilots that are Flying:
  1. PIC16f877 code crosses boundary @800h
    By inventosrl in forum mel PIC BASIC Pro
    Last Post: - 6th April 2009, 23:03
  2. Advice-scrutiny for my serial controller
    Last Post: - 13th December 2008, 18:11
  3. Serin serout problem
    Last Post: - 6th February 2007, 05:25
  4. Replies: 11
    Last Post: - 13th July 2005, 20:26
  5. SerIn and SerOut
    By Dwayne in forum FAQ - Frequently Asked Questions
    Last Post: - 21st July 2004, 16:54
