Arrays in assembly code
Results 1 to 3 of 3
    Bombay, India
    Default First you need the variable size
    How have you specified matrice ? If it is a byte sized variable, then your statements should be
    btfss _A8
    and _matrice+0,w
    btfss _A9
    and _matrice+1,w
    If your variable is a word sized variable, then you need to read/write word sized variables like this
    btfss _A8
    ;; read the word from matrice[0] assuming MSB first (Big endian)
    ;; movf matrice+0,w
    ;; movwf TempM ; read the msb
    ;; movf matrice+1,w
    ;; movwf TempL ; read the lsb
    ;; --- now perform the operation you desire here
    I hope I have been able to address your query
    Jerson
    Apr 2006
    Thumbs up
    Thanks Jerson,
    it's a byte sized array and it works!
    Thanks again
    Mario
  1. Cordic trig assembly code for PIC18f
    By ScaleRobotics in forum mel PIC BASIC Pro
    Last Post: - 8th September 2015, 06:36
  2. How much code space do PBP statements use.
    Last Post: - 13th February 2009, 22:31
  4. 4 Chanel Dmx512 ready assembly code to PBP ?
    By syscoder in forum mel PIC BASIC Pro
    Last Post: - 22nd March 2007, 00:55
  5. Your Suggestions: Assembly code material?
    By dw_picbasic in forum General
    Last Post: - 2nd February 2007, 18:33
