12f675 and midi!
Results 1 to 19 of 19
    uuups. sorry, you are right, there is no uart at the 12f675 ;-)
    look at the manual under SEROUT2 for calculating baud rate. 31250 baud needs a 20 mhz crystal.
    for analog in : some sample program with a 12F675 look at TESTX4.BAS
    i know it's only microcontrolling, but i like it!
    Alaskanphoenix's Avatar
    Alaskanphoenix Guest
    I tried to use an external 20 mhz xtal with the serout2 but nothing!
    Then i used the debug command with the internal xtal and finally some message appears but wrong,probably it can't reach 31250 baud! how can i disable the internal and use the external xtal?
    please post your code si we can take a look
    you can define the osc as usual, don't write any : @ DEVICE pic12F675, INTRC_OSC ' activates internal osc
    how looks your serout2 command?
    Lightbulb
    You set the use of an exernal oscillator in your programmer software, in your case you should look for HS oscillator. To make GP0 and 1 analog inputs, GP2 digital output and ADconverter 10bit, you should probably(never used the 12F675) use ....
    TRISIO = %00000011
    ANSEL = %00110011
    ADCON0 = %10000001
    ADvalue VAR WORD
    ADCIN 0,ADvalue ' Read channel 0
    ADCIN 1,ADvalue ' Read channel 1
    I want to use gp0 and gp1 as analog inputs and gp3 as digital out to send midi messages:
    DEFINE OSC 20
    DEFINE DEBUG_BAUD 31250 ' midi baud rate
    DEFINE DEBUG_REG gpio ' Set Debug pin port
    DEFINE DEBUG_BIT 2 ' Set Debug pin bit
    DEFINE DEBUG_MODE 0
    adval var byte ' Create adval to store result
    ANSEL = %00000011 ' ----DDAA
    CMCON = 7 ' Analog comparators off
    loop: ADCIN 0, adval ' Read channel 0 to adval
    debug $b0,$00,adval
    Pause 250 ' Do it all about 10 times a second
    Goto loop ' Do it forever
    how can i limit the results of analog inputs between 0-127?
    Thanks a lot
    divide adval by 2
    adval = adval / 2
    adval = adval >> 2
    Talking YESSSS!!!! IT WOrks!!!
    Thank you all very much!
    It finally works!
    I use the Hs oscillator and it works ok!
    One last question, why if i connect a pot in gpio.0 and rotate it the numbers don't start from 0 but from $7f, go to 0 and arrive to $7f?
    i use adval >> 2 to limit till $7F
    the pot values goes from 127 to 0 instead 0 to 127?
    then change the plus and minus on your pot, that changes the direction
