help me...
Results 1 to 5 of 5
Thread: help me...
    Default oops..
    PIC16F84A and max 232
    4Mhz
    using windows hyperterminal to communicate
    sorry not mention the component...
    is there any way that i can input a number or letter with more that 1 character in a single variable.?
    Default Is this PIC# will die one day?
    Seems to be a baudrate problem. Be sure you set this crap Hyperterminal Baudrate and all settings correctly first. Sorry... i hate Hyperterminal. That's the worst PC program i've never ever seen in my whole life. MicroCode Studio Serial Communicator is a good one.
    Try to remove the CHAR_PACING stuff first or change Terrminal program
    For what it worth, How about your schematics?
    Are you sure that your crystal really run @4MHZ ?
    For your last question, define an ARRAY variable of n elements then use SERIN2 with STR modifier.
    serin2 PORTA.2,t2400,[kdg.0,kdg.1 ]
    i'm pretty sure it's not a valid statement. Have a look to SEROUT, SEROUT2 modifier list
    Default can you...:)
    can you show me some example about using SERIN2 with STR modifier.
    i still confuse about SERIN ,SERIN2 and SEROUT, SEROUT2.
    please....
