help me...
Results 1 to 5 of 5
Thread: help me...
    Unhappy help me...
    INCLUDE "modedefs.bas"
    DEFINE CHAR_PACING 1000
    kdg var word
    pause 2000
    SerOut PORTA.3,t2400,["nilai",13,11]
    serin2 PORTA.2,t2400,[kdg.0,kdg.1 ]
    SerOut PORTA.3,t2400,["nilainya ",kdg.0,kdg.1,13,11]
    why the output show stange character??
    what wrong???
    Default You need help? Help us a bit
    PIC #
    OSC speed
    Hardware?
    Config Fuses?
    i suspect, at least, that your PIC have some analog stuff to be disable on PORTA
    Default oops..
    PIC16F84A and max 232
    4Mhz
    using windows hyperterminal to communicate
    sorry not mention the component...
    is there any way that i can input a number or letter with more that 1 character in a single variable.?
    Default Is this PIC# will die one day?
    Seems to be a baudrate problem. Be sure you set this crap Hyperterminal Baudrate and all settings correctly first. Sorry... i hate Hyperterminal. That's the worst PC program i've never ever seen in my whole life. MicroCode Studio Serial Communicator is a good one.
    Try to remove the CHAR_PACING stuff first or change Terrminal program
    For what it worth, How about your schematics?
    Are you sure that your crystal really run @4MHZ ?
    For your last question, define an ARRAY variable of n elements then use SERIN2 with STR modifier.
    i'm pretty sure it's not a valid statement. Have a look to SEROUT, SEROUT2 modifier list
    Default can you...:)
    can you show me some example about using SERIN2 with STR modifier.
    i still confuse about SERIN ,SERIN2 and SEROUT, SEROUT2.
    please....
