CAN support
Results 1 to 5 of 5
Thread: CAN support
    Apr 2006
    Michigan
    Is there any plan to add CAN. Looking at Mikrobasic, it has a whole can library. Will this be happening with PBP.
    New Jersey
    Default CAN Communication
    I am looking for an example of how to communicate with the CAN network. Our locomotive uses CAN for communication with the engine and I am looking to do something similar like you are doing. I am going to order the CAN communication board from Circuit-ED and start playing around with it. Can you share an example of transmitting and receiving with CAN?
    Chris
    Apr 2006
    Michigan
    if you simply want to read the CAN, I would recommend just buying something like a NeoVI which is sold by intrepid control systems. (Best tool I have found) It will read and send any messages you want and you can set up the software to interpret the messages in a matter of minutes. If you want to actually use the data to perform a function on you PIC, microchip has a lot of useful documents on their site for doing CAN. It explains the protocol and some example circuits both using the on Chip can and a stand alone IC. I must warn you CAN is a pretty complicated protocol.
  1. PBP PIC32 series support?
    By foss in forum mel PIC BASIC Pro
    Last Post: - 18th August 2008, 12:10
  2. Melabs PIC Basic Pro - 16 bit devices support
    By rod27cn in forum PBP Wish List
    Last Post: - 21st November 2007, 08:21
  3. PicBasic Pro CAN Support?
    By RMUTR in forum mel PIC BASIC Pro
    Last Post: - 18th November 2006, 00:19
  4. DSPIC Support
    By GeoJoe in forum PBP Wish List
    Last Post: - 5th May 2006, 15:47
  5. cell phone support text mode
    By microkam in forum mel PIC BASIC Pro
    Last Post: - 23rd July 2005, 10:05
