CAN support
Results 1 to 5 of 5
Thread: CAN support
    Apr 2006
    Michigan
    Default CAN support
    I would like to see some CAN in and out commands for the 18f series of micros with the integrated ecan.
    Apr 2006
    Michigan
    Default CAN support
    The reason I asked about a CANin/out command is because I work in the auto industry. I am using my PIC Basic Pro to make little gadgets for the assembly line to increase productivity. All of our vehicles now use CAN, so it would be really nice to be able to have these commands. I have been experimenting with using a stand alone controller, and I think I almost have it, but for cost and ease in the future, this would be nice.
    Apr 2006
    Michigan
    Is there any plan to add CAN. Looking at Mikrobasic, it has a whole can library. Will this be happening with PBP.
    New Jersey
    Default CAN Communication
    I am looking for an example of how to communicate with the CAN network. Our locomotive uses CAN for communication with the engine and I am looking to do something similar like you are doing. I am going to order the CAN communication board from Circuit-ED and start playing around with it. Can you share an example of transmitting and receiving with CAN?
    Chris
    Apr 2006
    Michigan
    if you simply want to read the CAN, I would recommend just buying something like a NeoVI which is sold by intrepid control systems. (Best tool I have found) It will read and send any messages you want and you can set up the software to interpret the messages in a matter of minutes. If you want to actually use the data to perform a function on you PIC, microchip has a lot of useful documents on their site for doing CAN. It explains the protocol and some example circuits both using the on Chip can and a stand alone IC. I must warn you CAN is a pretty complicated protocol.
  1. PBP PIC32 series support?
    By foss in forum mel PIC BASIC Pro
    Last Post: - 18th August 2008, 13:10
  2. Melabs PIC Basic Pro - 16 bit devices support
    By rod27cn in forum PBP Wish List
    Last Post: - 21st November 2007, 09:21
  3. PicBasic Pro CAN Support?
    By RMUTR in forum mel PIC BASIC Pro
    Last Post: - 18th November 2006, 01:19
  4. DSPIC Support
    By GeoJoe in forum PBP Wish List
    Last Post: - 5th May 2006, 16:47
  5. cell phone support text mode
    By microkam in forum mel PIC BASIC Pro
    Last Post: - 23rd July 2005, 11:05
