serial program and sensor problem
Results 1 to 5 of 5
    win_832001's Avatar
    win_832001 Guest
    Question
    TQ for the reply. actually i wrote this program for servo turn from 0 degree-90 degree. and the from 90 degree to 0 back. so the servo is only have to turn like that. so i'm not to modified the servo instead using standard servo.
    for the instruction :
    val=0
    For val=0 TO 80
    PulsOut PORTB.3,150 ' - servo rotate from 0 degree-90 degree
    the problem came on this:
    IF IRSwitch =1 Then
    Pause 1000
    GoSub CloseGate 'when the sensor =1 (this part is not working)
    EndIF
    GoSub Main
    For val=0 TO 80
    PulsOut PORTB.3,50 'servo rotation - servo rotate from 90 degree-0 degree:
    this instruction is working with servo is rotate but the problem is i need to send the data to make the servo run.
    actually, the things that i want is to the sensor =1 and no serial input to make the servo turn.
    tq for help me..
    Unhappy Servo command common values
    Hi, Win
    Servos pulses HAVE to respect those values ...
    700 to 2300 µS high level @ 20 to 60 Hz
    Not to create mechanical or electrical damage.
    Sometimes it's possible to try a wider range, but it doesn't fit all brands ...
    Your 50 value is out of range !!!
    Just try a value in the 70 - 230 range ...
    Note also the " @ 20 to 60 Hz " ... the pulse has to be sent every 50 to 15 ms ...
    win_832001's Avatar
    win_832001 Guest
    oooo...really..TQ for the reply..i'll try the value for the servo..
