serial program and sensor problem
Results 1 to 5 of 5
    win_832001's Avatar
    win_832001 Guest
    Post serial program and sensor problem
    i need a help here..i have a project that require serial program.the input is from visual basic. so i guess i have to use SERIN command. but then my project has to use as a switch.so,after that there is not require a input from serial but the input is from the switch as a input sensor.i give the program condition IF to run the program. but the program has do not working like that i want.need help please...
    the program should working as above :
    1)initially red LED flashed
    2)after vb send =1 and IRswitch=0 (servo pen and green LEd flashed)
    3)after IRswitch =1 (servo close and green LED-->RED led)- do not require serial input.
    the program that i wrote :
    INCLUDE "modedefs.bas"
    GreenLED VAR PORTB.4
    RedLED VAR PORTB.5
    SerialIn VAR PORTA.4 'serial programming
    IRSwitch VAR PORTB.1 'sensor
    PinState VAR BYTE
    val VAR WORD
    val = 0
    SerIn SerialIn,4,[255],PinState
    High GreenLED 'start condition
    Low RedLED 'start condition
    IF PinState=1 AND IRSwitch= 0 Then OpenGate 'when the vb send '1' and the sensor is = 0 (this part working)
    IF IRSwitch =1 Then
    Pause 1000
    GoSub CloseGate 'when the sensor =1 (this part is not working)
    EndIF
    GoSub Main
    OpenGate
    Pause 1000
    Low GreenLED
    High RedLED
    val=0
    For val=0 TO 80 'servo rotation (working)
    PulsOut PORTB.3,150
    Pause 20
    Next val
    GoSub Main
    CloseGate
    Pause 1000
    High GreenLED
    Low RedLED
    For val=0 TO 80 'servo rotation (not working)
    PulsOut PORTB.3,50
    Pause 20
    Next val
    GoSub Main
    -need help here please.TQ
    Red face RTFM First ...
    Hi, Win
    First :
    Have a closer look to subroutines writing:
    Sub1:
    - what you want
    looks much Better ...
    " For val=0 TO 80 'servo rotation (not working)
    PulsOut PORTB.3,50 "
    are you sure of the 50 value ??? ... I don't really think so.
    win_832001's Avatar
    win_832001 Guest
    Question
    TQ for the reply. actually i wrote this program for servo turn from 0 degree-90 degree. and the from 90 degree to 0 back. so the servo is only have to turn like that. so i'm not to modified the servo instead using standard servo.
    for the instruction :
    val=0
    For val=0 TO 80
    PulsOut PORTB.3,150 ' - servo rotate from 0 degree-90 degree
    the problem came on this:
    IF IRSwitch =1 Then
    Pause 1000
    EndIF
    GoSub Main
    For val=0 TO 80
    PulsOut PORTB.3,50 'servo rotation - servo rotate from 90 degree-0 degree:
    this instruction is working with servo is rotate but the problem is i need to send the data to make the servo run.
    actually, the things that i want is to the sensor =1 and no serial input to make the servo turn.
    tq for help me..
    Unhappy Servo command common values
    Hi, Win
    Servos pulses HAVE to respect those values ...
    700 to 2300 µS high level @ 20 to 60 Hz
    Not to create mechanical or electrical damage.
    Sometimes it's possible to try a wider range, but it doesn't fit all brands ...
    Your 50 value is out of range !!!
    Just try a value in the 70 - 230 range ...
    Note also the " @ 20 to 60 Hz " ... the pulse has to be sent every 50 to 15 ms ...
    win_832001's Avatar
    win_832001 Guest
    oooo...really..TQ for the reply..i'll try the value for the servo..
