18F1320 Clock running
Results 1 to 7 of 7
    Dave W's Avatar
    Dave W Guest
    Default 18F1320 xtal clock
    Hi Alain...
    Thanks for the response...
    Unfortunately I did try changing the xtal osc feedback caps...
    27pF down to 18pF... no luck...
    I tried the HS setting for the CONFIG1H register as well ... no luck...
    also using the HS setting in the meLabs serial programmer...
    I borrowed a better O'scope...
    It looks as if it's trying to start, at initial power up... but dies away..
    If you have any other ideas or resources to research.. I open...
    Dave W, If I might ask, who's crystals are you using? Do you have the spec's handy? I wouldn't giveup yet. Try putting a 1 Meg resistor across the oscin and oscout terminals with the crystal and 18pf caps in place.
    Dave W's Avatar
    Dave W Guest
    Default 18F1320 Xtal Clock
    Hello Dave...
    The xtal is a Citizen CM309S series...18pF Cl...
    I tried the 1Mohm R across the xtal... no luck...
    I also tried the series R from 10 ohm to 27 ohm... no luck
    Maybe a bit more background...
    Basically I have built 3 units... (I only had 3 PCB's built from the "quick turn" PCB house..)
    2 worked... 1 doesn't... using the same S/W code...
    but it took 6 - 18F1320 units to get the 2 working units....
    That's why I thought it may have been a S/W setup problem...
    The one key symptom is that the xtal osc isn't running...
    This happened before... but I think because of IC swapping... it went away...
    Dave W
    N9DQW
    Wink Stupid question ...
    Hi, Dave
    Did you tried to read the real config settings from the chip ONCE PROGRAMMED ???
    I had surprises also on this side ...
    Jun 2008
    Varese , Italy
    Default Re: 18F1320 Xtal Clock
    Hi !
    I have to transfer a program from a pic16f628 to a PIC18F1320 enviroment..
    The program runs well on the 628 but it does not on the 1320.
    The prg compiles OK using PBP pro and the micro is programmed OK with ICD2 programmer.
    I use a 20 Mhz XTAL osc and it is running as seen by the scope.
    Any help for me to configure the new 1320 ?
    Thanks in advance.
    Ambrogio
  1. Single digit 7 Seg LED clock - PIC16F88
    By thirsty in forum Code Examples
    Last Post: - 17th July 2009, 09:42
  2. UberNewbie can't set his clock...
    Last Post: - 7th January 2009, 05:22
  3. EM4095 Chip, get Clock and Data signals?
    By mindthomas in forum mel PIC BASIC Pro
    Last Post: - 19th August 2008, 07:27
  4. Shiftout/in
    By BobEdge in forum mel PIC BASIC Pro
    Last Post: - 23rd August 2007, 12:48
  5. Help with sound command in 2 programs
    Last Post: - 5th July 2007, 21:36
