Voltage compliance issues
Results 1 to 2 of 2
    Alexterrell's Avatar
    Alexterrell Guest
    Default Voltage compliance issues
    Hi there,
    The European Union introduced loads of regulations for Low voltage, but
    then defines this as 75V - 1000V DC.
    I'm working on a product that runs off 4.5 - 7.5 volts, powered by a
    transformer or switch mode power supply. Obviously the transformer /
    switchmode power supply needs to be approved and meet standards.
    Can some one tell me if there are electical standards relating to
    products running at 4.5 to 7.5 volts?
    Alex
    Jan 2006
    Istanbul
    Exclamation
    Here is the link.
    http://ts.nist.gov/ts/htdocs/210/gsi...-812/page2.htm
    If you had a battery operated device, you would not need to comply with this directive.
    Since you have a power supply and it will have an input voltage of 220VAC, you must comply with the directive. However, only the power supply must comply with the directive not the device that is running with 4.5 to 7.5v.
  1. high voltage high frequency H-Bridge
    By George in forum Off Topic
    Last Post: - 27th April 2009, 12:50
  2. Expanded Scale Voltmeter
    By Pic_User in forum Schematics
    Last Post: - 8th February 2008, 21:32
  3. Help with final project
    By OvERKiLL in forum General
    Last Post: - 15th December 2006, 21:35
  4. Project-Read voltage in / different voltage out
    By andydoc in forum mel PIC BASIC
    Last Post: - 8th August 2005, 16:20
  5. Low Voltage Detection
    By Srigopal007 in forum mel PIC BASIC Pro
    Last Post: - 5th January 2005, 19:29
