asm e picbasic
Results 1 to 6 of 6
Thread: asm e picbasic
    Dec 2005
    Unhappy asm e picbasic
    Hi all,
    I have a problem. After compiling, PicBasicPro generates a warning error:
    Error[118]C:\test.asm53: Overwriting previous address contents (000E)
    Error[118]C:\test.asm54: Overwriting previous address contents (000F)
    Error[118]C:\test.asm55: Overwriting previous address contents (0010)
    Error[118]C:\test.asm56: Overwriting previous address contents (0011)
    Error[118]C:\test.asm57: Overwriting previous address contents (0012)
    Error[118]C:\test.asm58: Overwriting previous address contents (0013)
    and so on.. It does not work. Why?
    this is code:
    define LCD_DREG PORTB
    DEFINE LCD_DBIT 4
    DEFINE LCD_RSREG PORTB
    DEFINE LCD_RSBIT 3
    DEFINE LCD_EREG PORTB
    DEFINE LCD_EBIT 2
    BSF STATUS,5
    movlw 00000b
    MOVWF TRISA
    BCF STATUS,5
    LED BSF PORTA,0
    lighting:
    LCDOUT $fe,1,"light!"
    THX
    chip
    What PIC, what PBP version?
    Dec 2005
    Smile version
    Hi Melanie,
    I have PicBasicPro version 2.46
    PIC: 16f84a & 16f877a
    thx
    chip
    I get...
    [235] Opcode Expected Instead of 'LED'
    ...which is pretty understandable since your posted code isn't complete!
    Dec 2005
    Default sorry Melanie..
    "code complete"
    DEFINE LCD_DREG PORTB
    DEFINE LCD_DBIT 4
    DEFINE LCD_RSBIT 3
    DEFINE LCD_EBIT 2
    ORG 0X0C
    CONT RES 2
    BSF STATUS,5
    movlw 00000b
    MOVWF TRISA
    MOVLW 00000000B
    MOVWF TRISB
    BCF STATUS,5
    BSF PORTA,0
    CALL DELAY
    BCF PORTA,0
    CALL DELAY
    DELAY
    D1 DECFSZ CONT,1
    GOTO D1
    D2 DECFSZ CONT+1,1
    GOTO D2
    IF (PORTA.0 = 1) THEN LIGHT
    IF (PORTA.0 = 0) THEN NO_LIGHT
    LIGHT:
    LCDOUT $FE,1,"LIGHT"
    NO_LIGHT:
    LCDOUT $FE,1,"NO_LIGHT"
    Fisrtly your code isn't going to work... you got serious logical errors (the code is a bit of a mish-mash... have you simply cut & paste or do you have a plan and know what you're doing?)... but that aside...
    If you're going to mix Assembler and PICBasic you can't specify a low-order ORIGIN (your ORG statement), because PICBasic will start assembling it's code down there. If you really need to specify a fixed location for your code, dump it in high memory space, well away from where PICBasic will place it's code.
  1. ASM cycles in PICBASIC
    By breeno in forum General
    Last Post: - 10th July 2006, 09:59
  2. Replies: 22
    Last Post: - 12th July 2005, 18:39
  3. Can an asm interrupt contain gosub to a picbasic routine?
    By sougata in forum mel PIC BASIC Pro
    Last Post: - 21st April 2005, 20:49
  4. Asm To Picbasic Disassembler
    Last Post: - 10th December 2003, 08:48
  5. asm to picbasic
    By wilfried in forum mel PIC BASIC Pro
    Last Post: - 12th March 2003, 02:18
