18F1320 ... Strange Memory
Results 1 to 40 of 44
    Probably the only thing you'll have for your 2$ is a smile... and again LOL!
    Italy
    Alain,
    What is the manufacturing date code of your 18F1320?
    Luciano
    Picture from the internet:
    Hi,Luciano
    I have 05250SE as a code.
    I bought them at the end of last year ( 2005 ) from FARNELL.
    I've seen the errata giving an increasing EEPROM Writing time from 4 to 5.5 ms ...
    may be, MPLAB didn't follow ...
    something strange is I have to program it in 4 times ( ! ) to get 100% success
    1) Erase all
    2) Config words only( Ok only at second pass ...)
    3) Program only
    4) EEPROM only
    setting to "Auto select" fails at each trail ... " Erase all at first" too
    Maybe MPASM don't follow or just consider the newer device... I'll not be surprise if so...
    Let's see what Melanie will discover with her brand new version.
    Acetronics, Last year I worked on a project for almost 4 months trying to get an 18F1320 to operate @ 40 Mhz. and then @ 20 Mhz. with eratic results. After looking at the data sheet I decided to use the 16F88 and have never gone back to the 18F1320. The errata sheets tell all. I ordered parts from DigiKey and they said that they had the latest hardware on hand but after receiving 50 parts of an old revision I gave up ordering from them. I was on the MicroChip forum for about 2 months and found out that they wern't very stable as far as the PLL goes and very sensitive to power supply variations. Like I said after looking at the data sheets of the 2 I decided to go with the 16F88 and haven't looked back yet. LOL
    Italy
    Alain,
    The oscillator speed of your PIC is 20MHz.
    Can you try to change "DEFINE OSC 20" in "DEFINE OSC 25" and flash
    the PIC running at 20 MHz with this code? If you try that you will
    probably increase the EEPROM writing time and see if ONE write is
    enough. This is just a test.
    Best regards,
    Luciano
    EDIT:
    Are you absolutely sure that the oscillator speed is correct?
    Unhappy
    Quote Originally Posted by Luciano
    Alain,
    Best regards,
    Luciano
    EDIT:
    Hi,Luciano
    Sorry, but that won't give anything ... as the EEPROM writing time is controlled by the PIC Hardware ...
    For the Osc speed, it's correct : 1.52 ms input signals give ( 279 + 7H ) Hex.
    ( EEPROM addresses are: 01 high byte, 02 low byte, and 30 Offset )
    Thanks for the idea ...
  1. Strange pic 16f877a memory loss
    By DavyJones in forum General
    Last Post: - 6th July 2009, 21:27
  2. Need the code to write to a memory
    By Hamlet in forum General
    Last Post: - 20th August 2007, 01:22
  3. Replies: 4
    Last Post: - 2nd March 2007, 07:12
  4. sample code for M25P32
    By Pedro Santos in forum mel PIC BASIC Pro
    Last Post: - 9th January 2007, 03:37
  5. Use internal program memory like DATA memory
    Last Post: - 30th December 2006, 19:38
