18F1320 ... Strange Memory
Page 1 of 2 12 LastLast
Results 1 to 40 of 44
    Question 18F1320 ... Strange Memory
    Hi all,
    I wrote a nice piece of code ( 3200 hex lines ...) for a 16F648 an a 16F88 : Everything works OK ! ... thank you.
    BUUUUUT, Trying to use it aboard a 18F1320 ... things become quite funny :
    Let's see:
    Program runs ... but...
    I have to memorize in the EEPROM 8 values "in a row" ( from 1 to 8 ) and then Three others, one by one, at locations 10,11, and 12.
    The first 8 are well Stored ... but the 3 others never want to be stored !!!
    Somewhere else, after that, I can modify values 1 and 2 ...
    They are properly modified and stored !!!!
    So, shortly ... my 18F1320 seems to have only 8 addressable EEPROM registers.
    I tried to push the 3 lonesome values to $11, 12 and 13 ... no more result.
    Anyone understanding that ???
    ( Setting WREN to 1 doesn't modify anything ... )
    Unhappy
    Hi, Mel
    No idea ???
    ( source has of course being written in PbP ... ~ 700 lines )
    Italy
    Disable interrupts when you write the internal EEPROM.
    (From the datasheet).
    Can you write a small PicBasic program that only
    write and read the byte at location 10?
    Can you write location 10 with a chip programmer and
    then read the same location with PicBasic?
    Can you write a small assembly program that only
    (See datasheet).
    Best regards,
    Luciano
    Kinda difficult to comment without seeing the code that reads and writes to the EEPROM... really as Luciano states, create some simple code to write to EEPROM, then read it back and verify.
    What I normally do, is also read the EEPROM back in my Programmer (always assumining your has that capability) and doubly confirm what I've written is actually stored there. That way you can concentrate on debugging the READ or the WRITE part of your code.
    Of course you do have the latest PBP and MPLAB that has eliminated the internal EEPROM anomalies of the earlier versions?
    Feb 2005
    Kolkata-India
    Default Is your PIC code protected
    I once found on a PIC18F452 that if I codeprotect the first 512 bytes (boot) of the chip then my eeprom storage would no longer work. Leaving it out and protecting the other pages did the trick.
    Sougata
    Unhappy Nothing new at sight ...
    Hi, Mel and Luciano
    PbP is 2.46 "patched" release, and MPASM v 5.02 ... and ... no chance to use PM here !!! ( 18F1320 not supported ... it says)
    If you want, I send you the code ... no secrets there !!!
    There are no interrupts in this program ... I ever try not to use ... to avoid input parasitic signals difficulties ...
    I've read memory w/ my picstart ... that's how I found what was happening.
    The only thing I didn't try was to write into the memory not only 8 but, say, 20 values following each others...
    I changed the values types ... no more luck !!!
    And do not forget memory use is OK with 16F devices ...
    Thanks for your Help
    Unhappy Waterloo , sad country ...
    Last news :
    I added a value at position 9 (0 ) and copied the "writes" from location 1 to 9 to 21 to 29 ...
    result : all values Written ... except value at loc.2 that has been overwritten by "FF" .... my three lonesome further values always aren't written.
    may be there are overwritten too ... i'll never know.
    one sure thing ... there's a writing problem !!!
    Hi, SOUGATA
    All writing protections have been removed ... I have to program in two times : at first config , and then program. default configs locks the programming !!!
    Italy
    WRITE 2,NeutreC.lowbyte
    WRITE 1,NeutreC.highbyte
    WRITE 4,GaucheC.lowbyte
    WRITE 3,GaucheC.highbyte
    WRITE 6,DroiteC.lowbyte
    WRITE 5,DroiteC.highbyte
    WRITE 7,Invert   <<<<<<<<< Invert is declared as BIT
    WRITE 8,Side   <<<<<<<<< Side is declared as BIT
    I don't use PicBasic.
    Will "WRITE" support the BIT data type?
    Try to declare the variables Invert and Side as BYTE.
    Best regards,
    Luciano
    Hi, Luciano
    Bit is well written in the EEPROM ...
    inteco's Avatar
    inteco Guest
    I notice some problem with the programmer software too
    in writing the EEPROM data for the memory location.
    But seems melabs has corrected on their newer ver 3.31.
    I can tell from running debugging while reading the EEPROM
    data via rs232.
    Unhappy Strange, Strange ...
    I've tried to see closer what's happening, so :
    Values are Written 3 times, at locations 1-12 , then 21-32, then 41-52 ...
    Memory is filled w/ zeros at programming time
    Then run ...
    Attached is the EEPROM Dump ...
    Locations $0A, $0B and $0C are a bit surprising ... Values should have been $7F ... as loc. $1E, $1F, $20 and $32, $33, $ 34.
    a bug somewhere ???
    Italy
    Alain,
    Can you try declare the variables Invert and Side as BYTE?
    (Just a quick test).
    Best regards,
    Luciano
    Unhappy
    Sorry Luciano
    Same result ...
    Red face Finally got it ... but not good job !!!
    Hi all,
    I finally got it ...
    But I had to memorize 2 times the values ... and read the second writings.
    So, I think ...
    one lonely WRITE command writes the value FF instead of what you want !!!
    I stop here ...
    Working program attached ...
    PS:
    for curious guys ... that is just a simple R/C gadget to use two servos in parallell ... Neutral, 2 1/2 travels, finely adjustable, plus invertible rotation for servo n°2 ...
    There's also a fail-safe ... servos are driven to their neutral ( recorded ...) position, if signal lost.
    Plus visual programming help w/ three LEDS ...
    Yessss ....
    No, you have a problem... WRITING the value TWICE is not correct.
    You DO need up-to-date PBP and MPLAB (MPASM) as there was an EEPROM issue going back to v2.45 I think. Half the problem was Microchips Assembler too. Latest versions of everything work as expected in this department. Unfortunately I don't have that particular PIC to confirm your results.
    http://www.picbasic.co.uk/forum/showthread.php?t=547
    Talking Thanks , Mel, but ...
    My PbP and MPASM are the last versions : I verified it this morning ... and re-loaded PbP and its patch
    PbP 2.46 Patched and MPASM 5.02 ...
    Sorry, Mel ...
    You have CONFIRMED you are invoking the latest PBP and MPASM and not an old installed version by mistake or error in path statements?
    Default Sorry ...
    YES, I do confirm ... old versions are always thrown to the trash box ...
    PbP used version seen in the MPLAB / Output/ Build window too ...
    Just because I'm a nice girl, I've ordered one... hopefully, I'll have a 18F1320-I/P tomorrow...
    Wink Humour at the end
    Hi, Mel
    And you know why I tried to use the 18F1320 ???
    Just because 16F648 and 16F88 are not so easy to find by one part ...
    This gadget will be published this summer inside THE only FREE model Webzine ( http://aeronews.free.fr/index.html ) ... no money to earn for me .. or so little !!!
    .... Funny, I got This from Jeff Schmoyer ...
    " If it works well with the 16F88, you might want to stick
    to that device. You might also want to compare the
    erratas from Microchip on the devices you are using. "
    What to think of that ???
    Thanks for your Help,
    That's maybe just another Microchip way of reinvent the wheel.... This may be another specific device who need another special method to write to eeprom and plah plah... BUT how about if you use the assembler method stated in the datasheet AND/OR errata to write to the eeprom?
    Could also be another MPASM problem... wich is still possible. Did you contact Microchip tech-Support http://support.microchip.com Usually they answer within 24 hours
    Sorry Alain i don't have any handy 18F1320 to test it. I'll order some sample for myself too to play with them when health permit to stay awake more than 1 hour steady.
    I'm thinking that swapping a $2 part for the most expensive item on the menu at Le Cinq next time I'm in Paris is a good investment *smiles*
    Probably the only thing you'll have for your 2$ is a smile... and again LOL!
    Italy
    Alain,
    What is the manufacturing date code of your 18F1320?
    Luciano
    Picture from the internet:
    Hi,Luciano
    I have 05250SE as a code.
    I bought them at the end of last year ( 2005 ) from FARNELL.
    I've seen the errata giving an increasing EEPROM Writing time from 4 to 5.5 ms ...
    may be, MPLAB didn't follow ...
    something strange is I have to program it in 4 times ( ! ) to get 100% success
    1) Erase all
    2) Config words only( Ok only at second pass ...)
    3) Program only
    4) EEPROM only
    setting to "Auto select" fails at each trail ... " Erase all at first" too
    Maybe MPASM don't follow or just consider the newer device... I'll not be surprise if so...
    Let's see what Melanie will discover with her brand new version.
    Acetronics, Last year I worked on a project for almost 4 months trying to get an 18F1320 to operate @ 40 Mhz. and then @ 20 Mhz. with eratic results. After looking at the data sheet I decided to use the 16F88 and have never gone back to the 18F1320. The errata sheets tell all. I ordered parts from DigiKey and they said that they had the latest hardware on hand but after receiving 50 parts of an old revision I gave up ordering from them. I was on the MicroChip forum for about 2 months and found out that they wern't very stable as far as the PLL goes and very sensitive to power supply variations. Like I said after looking at the data sheets of the 2 I decided to go with the 16F88 and haven't looked back yet. LOL
    Italy
    Alain,
    The oscillator speed of your PIC is 20MHz.
    Can you try to change "DEFINE OSC 20" in "DEFINE OSC 25" and flash
    the PIC running at 20 MHz with this code? If you try that you will
    probably increase the EEPROM writing time and see if ONE write is
    enough. This is just a test.
    Best regards,
    Luciano
    EDIT:
    Are you absolutely sure that the oscillator speed is correct?
    Wink Not a soft problem ...
    Quote Originally Posted by mister_e
    Hi, Steve
    I looked at the 2 methods µchips proposes ( Sleep/ Wake on Interrupt or WR polling ) ...
    In fact the two methods are based on the WR bit clearing ... so why would one be better than the other !!!
    Writing time is given by the hardware ... no way to increase it !!!
    PbP uses the polling method, and I don't see anything hazadous in that the GIE bit is firmly set to 0 ... and I never set it to 1 in that program.
    Hope you'll soon be on your legs ...
    Amitiés from the " Maudit Français"
    Unhappy
    Quote Originally Posted by Luciano
    Alain,
    Best regards,
    Luciano
    EDIT:
    Hi,Luciano
    Sorry, but that won't give anything ... as the EEPROM writing time is controlled by the PIC Hardware ...
    For the Osc speed, it's correct : 1.52 ms input signals give ( 279 + 7H ) Hex.
    ( EEPROM addresses are: 01 high byte, 02 low byte, and 30 Offset )
    Thanks for the idea ...
    Italy
    Alain,
    I understand that at completion of the write cycle, the WR
    bit is cleared in hardware and the EEPROM Interrupt Flag bit
    (EEIF) is set. The user may either enable this interrupt
    or poll the WR bit. There is also a third barbarous method which
    is just wait 10 ms.
    In your post you say that PbP uses the polling method. This
    should be ok if the microcontroller hardware has no bug.
    Can you put a "PAUSE 10" after each WRITE in your code?
    (10 ms pause).
    Best regards,
    Luciano
    Unhappy
    Sorry one more time, Luciano ... the problem only occurs with a single writing !!!
    a Pause won't change anything ... and won't change the EEPROM writing time.
    Italy
    Alain,
    From the revision history of the 3 documents....
    - PIC18F1220/1320 Rev. B1 Silicon/Data Sheet Errata
    - PIC18F1220/1320 Rev. B4 Silicon/Data Sheet Errata
    - PIC18F1220/1320 Rev. D0 Silicon/Data Sheet Errata
    ... I can see that the silicon B1 and B4 have suffered from
    silicon EEPROM issues. For the silicon D0 there is only a
    change in the Data Sheet. No silicon EEPROM issues. (For now).
    Your project is going to be published in a magazine.
    Will your readers have always the right silicon version of
    the 18F1320, the right MPASM version and the right PBP version?
    Are you going to publish three different software versions
    with the workarounds suggested by Microchip? This will be
    difficult to manage for your readers.
    From your replies in this thread I only see your determination
    to make your project work with this chip, regardless if the chip
    has a problem or not. I am surprised when you say that the problem
    only occurs with single byte writing. As you already know, if
    you look at your EEPROM dump file you will see that the same 11
    values are written 3 times at different addresses. This is one
    problem. The "FF" you get when your PBP program writes only one
    byte is one more problem. (When PBP WRITE is called only once).
    Note that this byte is also written 3 times, first time "FF" and
    then twice again with the correct value "7F" at different addresses.
    The "FF" is probably an incomplete write. (EEPROM auto clear
    before write).Is the EEPROM dump file correct? Can you confirm it
    by reading the 256 bytes with a test program? How many chips did
    you try? There are many questions still open. If you can only program
    with PBP, then a pause of 10 ms after each of the 11 WRITE could maybe
    show something new in the dump file. If you don't have time to write
    some test code then just use a 16F648 or a 16F88 for your publication
    in the internet magazine.
    Best regards,
    Luciano
    http://ww1.microchip.com/downloads/e...Doc/80160f.pdf
    DOCUMENT REVISION HISTORY
    Rev A Document (06/2003)
    First revision of this document, silicon issues 1 (Data
    EEPROM), 2 (Data EEPROM), 3 (Core), 4 (INTOSC),
    5 (Internal Oscillator Block), 6 (Internal Oscillator
    Block), 7 (Electrical Specifications), 8 (EAUSART),
    9 (EAUSART) and 10 (EAUSART) and Data Sheet
    Clarification issues 1 (Internal RC Accuracy) and 2 (DC
    Characteristics Table).
    Rev B Document (10/2003)
    Added silicon issue 1 (Core).
    Rev C Document (12/2003)
    Removed silicon issue 2 (Data EEPROM). Changed
    silicon issue 8, 9 and 10 (was issue 9, 10 and 11) from
    EAUSART to USART. Added silicon issue 11 (Data
    EEPROM).
    Rev D Document (05/2005)
    Removed silicon issue 7 (Electrical Specifications),
    added silicon issue 11 (Reset), changed previous label
    of USART to EUSART in silicon issues 7, 8 and 9 (to be
    consistent with the data sheet) and added Data Sheet
    Clarification issue 1 (CCP).
    Rev E Document (08/2005)
    Added Data Sheet Clarification issue 2 (Data EEPROM
    Memory).
    Rev F Document (03/2006)
    Corrected part number revision IDs in the table on page
    one.
    http://ww1.microchip.com/downloads/e...Doc/80175e.pdf
    Rev A Document (12/2003)
    First revision of this document, silicon issues 1 (Core),
    2 (EUSART) and 3 (Data EEPROM) and Data Sheet
    Rev B Document (2/2004)
    Added silicon issue 4 (EUSART). Added Data Sheet
    Clarification issue 3 (Timer1 Oscillator and In-Circuit
    Serial Programming).
    Rev C Document (4/2004)
    Added Data Sheet Clarification issues 4 (DC
    Characteristics) and 5 (LVD Characteristics).
    Added silicon issue 5 (Reset) and removed all Data
    Sheet Clarification issues with the exception of former
    issue 3 (Timer1 Oscillator and In-Circuit Serial
    Programming™), now numbered issue 1 and added
    issue 2 (CCP).
    Removed Data Sheet Clarification issue 1 and added
    issue 2 (Data EEPROM Memory).
    http://ww1.microchip.com/downloads/e...Doc/80244b.pdf
    Rev A Document (08/2005)
    First revision of this document. Includes silicon issues 1
    (Core), 2 (EUSART), 3 (Reset) and 4 (Oscillator
    (INTOSC Source)), and Data Sheet Clarification issues
    1 (Timer3 (Special Event Trigger)) and 2 (Data
    EEPROM).
    Rev B Document (03/2006)
    Removed previous silicon issue 4 and added new silicon
    issues 4 (Oscillator/INTOSC) and 5 (Oscillator/INTRC).
    Data Sheet Clarification issue 1 (CCP) clarified as
    Timer3/Special Event Trigger.
    I've studied two chips...
    Both have a Batch Code of 05250SE and a Silicon Revision of DEVID2=07h DEVID1=C4h (located at 3FFFFEh and 3FFFFFh respectively).
    This is my Test Code, run on internal Oscillator at 4 and then at 8MHz... compiled with PBP2.46 with patches and MPASM 5.01.
    	'	EEPROM Test Program for PIC18F1320
    	'	Melanie
    	'	07/04/2006
    	'	PIC Defines
    	@ __CONFIG  _CONFIG1H, _IESO_OFF_1H & _FSCM_OFF_1H & _INTIO1_OSC_1H
    	@ __CONFIG  _CONFIG2L, _PWRT_ON_2L & _BOR_OFF_2L & _BORV_20_2L
    	@ __CONFIG  _CONFIG2H, _WDT_ON_2H & _WDTPS_32K_2H
    	@ __CONFIG  _CONFIG3H, _MCLRE_OFF_3H
    	@ __CONFIG  _CONFIG4L, _DEBUG_OFF_4L & _LVP_OFF_4L & _STVR_ON_4L
    	@ __CONFIG  _CONFIG5L, _CP0_OFF_5L & _CP1_OFF_5L
    	@ __CONFIG  _CONFIG5H, _CPB_OFF_5H & _CPD_OFF_5H
    	@ __CONFIG  _CONFIG6L, _WRT0_OFF_6L & _WRT1_OFF_6L
    	@ __CONFIG  _CONFIG6H, _WRTC_OFF_6H & _WRTB_OFF_6H & _WRTD_OFF_6H
    	@ __CONFIG  _CONFIG7L, _EBTR0_OFF_7L & _EBTR1_OFF_7L
    	@ __CONFIG  _CONFIG7H, _EBTRB_OFF_7H
    	'	Hardware Defines
    		'	PIC Speed
    	Define OSC 8
    		' 	LCD Display
    	Define LCD_DREG PORTB				' Port for LCD Data
    	Define LCD_DBIT 4				' Use upper 4 bits of Port
    	Define LCD_RSREG PORTB				' Port for RegisterSelect (RS) bit
    	Define LCD_RSBIT 3				' Port Pin for RS bit
    	Define LCD_EREG PORTB				' Port for Enable (E) bit
    	Define LCD_EBIT 2				' Port Pin for E bit
    	Define LCB_BITS 4				' Using 4-bit bus
    	Define LCD_LINES 2				' Using 2 line Display
    	Define LCD_COMMANDUS 2000			' Command Delay (uS)
    	Define LCD_DATAUS 50				' Data Delay (uS)
    		'	Other Ports
    	LED var PortB.0
    	'	Software Defines
    	CounterA var BYTE				' Just a Counter
    	DataA var BYTE					' Byte Variable for Data
    	DataB var BYTE
    	EEPROMError var BIT				' Error Flag
    	'	EEPROM Presets
    	Data @0,"This is a Test String that should be overwritten"
    	Data	"by the Write to EEPROM routine"
    	'	Start Program Here
    	'	Initalise PIC
    	OSCCON=%01110010
    	ADCON1=%01111111
    	TRISB=%00000000
    	Low LED
    	Pause 2000
    	High LED
    	'	Write to EEPROM
    	LCDOut $FE,1,"Writing EEPROM",$FE,$C0,"A="
    	For CounterA=0 to 255
    		DataA=255-CounterA
    		LCDOut $FE,$C2,#CounterA
    		Write CounterA,DataA
    		Next CounterA
    	LCDOut $FE,1,"Write Complete"
    	Pause 2000
    	'	Read & Verify EEPROM
    	EEPROMError=0
    	LCDOut $FE,1,"Verifying EEPROM",$FE,$C0,"A="
    		Read CounterA,DataA
    		DataB=255-CounterA
    		If DataA<>DataB then
    			LCDOut $FE,$C6,"E=",HEX2 DataB
    			LCDOut $FE,$CB,"R=",HEX2 DataA
    			EEPROMError=1
    			Pause 2000
    			LCDOut $FE,$C6,REP 32\11
    		Next CounterA
    	'	Result
    	LCDOut $FE,$C0,"Chip Test "
    	If EEPROMError=0 then
    		LCDOut "Pass"
    		LCDOut "Fail"
    EndLoop:
    	Pause 500
    	Toggle LED
    	Goto EndLoop
    And the result?
    One chip fails miserably, and the other works perfectly. The appended picture shows the good PIC passing at 8MHz... frequency counter is measuring Internal Oscillator OUT on RA6 which is fosc/4.
    The PIC that failed did NOT write to EEPROM... it's previous contents were untouched, the Read section reported $FF from every memory Location (that had not previously been preset by a DATA statement). I have not had time to impliment the ERRATA (Section 10 Page 3) suggestions from Microchip and verify if the dud PIC works with one or both of them.
    Alain, email or message me your address off-list and I'll send you the working PIC - you can then see if your program works on that.
    Wink Truth slowly raises from earth ...
    Hi, Mel
    What a nice Job .... "La Claaaasse" as we say here !!!
    just one comment: I noticed here memory locations were ERASED to FF instead of Written to expected values ...
    For my tests I programmed all EEPROM to zero .... and I read some "FF" 's
    see attachment for that.
    You're right ... result is the same. In this case not exactly !!! I did a little mistake Testing at the beginning unwritten Offsets as Words ( Declared as bytes ... no, not on the head, please ...).
    So, without this little mistake, I'd never had found this BUG ... my program would simply have locked at 2nd power-up !!!
    My Address is not a secret ...
    xxx
    FRANCE
    Close to DIEPPE or Le Tréport along the Channel, for your next visit to France ( at home coffee is free ...)
    Thanks one more time
    Hi, Luciano
    Nice result from you too ... Microchip search engine can be upgraded, I didn't find anything in the knowledge base !!!
    This device is intended to be used on big scale flying models ...
    so, security first !!! ... no 18F1320 reference or soft will be published then ( I saw some, last year on another project ... gasp !!! ).
    I'll do a trail with BOR enabled to the lowest possible voltage to confirm ... as, to this day, std. 4.3v BOR enabled was equal to plane death !!!
    I'll wait for BUGS to be solved ... to use a 18F1320.
    As Mel has written, There's no "common people" way of identifying good and bad parts ... my Picstart didn't allow me to read DEVIDs ... ( restricted area !!! ) .
    Thanks a lot for your help ( in general on this forum ) and here for me.
    Last edited by Acetronics2; - 15th May 2010 at 10:38. Reason: Deleted my own address ...
    Btw... I checked EEPROM WRITE on the good PIC all the way down to 2.15v Vdd and it works fine. It's on it's way to you first thing Monday morning.
    When you get it, send back one of your duds to me... they're more interesting to play with than working ones.
    Default THE Thing
    Of course, the red servo is the master, and the black one, the ... slave.
    French humour must go on !!!
    Mel, I have a piece w/ pin B.0 "grilled" ( but processor running ) ... do you want it too ??? It has been socketed Upside Down ... during the 122 th trail !!!
    Wink Luciano : 2 Points ...
    Hi, Luciano
    I've set BOR to ON ... then writing is correct !!!
    You're the winner of the day ...
    Italy
    Alain,
    Your chip is a D0 Silicon version. (Same date as Melanie).
    If I am the winner of the day, Microchip is the loser of the day because
    they will have to add this workaround also in the Errata Silicon D0 document.
    Glad to hear that things are moving forward!
    Best regards,
    Luciano
    Angry One more BUG ...
    It was rather difficult to program the chip ... W/ my Picstart
    I cleared my program from " double writings " ...
    Now, it's become impossible to re-program the chip ...
    only config can be entered at the THIRD try ...
    EEPROM at the first ...
    All the program memory is read as FF ...
    ERROR ...ERROR ... ERROR ....
    Trash BOX !!!
  1. Strange pic 16f877a memory loss
    By DavyJones in forum General
    Last Post: - 6th July 2009, 20:27
  2. Need the code to write to a memory
    By Hamlet in forum General
    Last Post: - 20th August 2007, 00:22
  3. Replies: 4
    Last Post: - 2nd March 2007, 06:12
  4. sample code for M25P32
    By Pedro Santos in forum mel PIC BASIC Pro
    Last Post: - 9th January 2007, 02:37
  5. Use internal program memory like DATA memory
    Last Post: - 30th December 2006, 18:38
