pwm to pin using variable
Results 1 to 4 of 4
    wsmrite's Avatar
    wsmrite Guest
    Default pwm to pin using variable
    I want to send a PWM output to a pin that is chosen at random. How do I specify the PIN in the PWM syntax using a variable generated by RANDOM?
    I.E. I would normaly send:
    PWM PORTD.0, 155,50
    Want to send:
    PWM "random pin",155,50
    Where "random pin" would be a variable generated by a previous RANDOM command being a number between 0 and 7 corresponding to the pin number on port D. I know how to generate the random number I need to know how to use a variable for the pin in the PWM command.
    Red face use an array?
    You could define an array, then have your random # be the array element pointer (after defining each element).
    ------------Picster--------------
    too do this easy you'll be limited to the available pin number stated in section 4.11 in the PBP manual.
    Wink With a little brain work ...
    Hi, writer
    Manual section 5.61 ... you just have to format your random number to meet section 4.11
    Rather Easy ...
  1. Is this a K Type sensor?
    Last Post: - 21st November 2009, 13:55
  2. Variable PWM PIC18F2431
    By trr1985 in forum mel PIC BASIC Pro
    Last Post: - 12th June 2009, 06:03
  3. Help with sound command in 2 programs
    Last Post: - 5th July 2007, 20:36
  5. Another RTC, DS1287
    Last Post: - 12th December 2006, 17:07
