SELECT CASE for ranges of values
Results 1 to 18 of 18
    caverman's Avatar
    caverman Guest
    Unhappy opps, need to add more
    or something like
    select case PulseLength
    case is > 165 and is < 176
    OutValue=0
    case is > 184 and is < 192
    OutValue=1
    end select
    Dirk
    New England
    Seems like maybe some 'IF... THEN's might work out better?
    caverman's Avatar
    caverman Guest
    Smile Thanks
    Funny how late at night one gets stuck into a Select method without thinking of the obvious easy If solution
    caverman's Avatar
    caverman Guest
    Lightbulb But
    But maybe the PICBASIC people could add the CASE x TO y variety that some BASICs have.
    caverman, Why make a mountain out of a Mole hill. Just do this:
    case is < 165
    you don't want these values because they are below 165 so do something
    case is < 176
    OutValue=0
    case is < 184
    you don't want these values because they are between 176 and 184 so do something
    case is < 192
    OutValue=1
    case else
    you don't want these values because they are between 192 and 255 so do something
    end select
    This is the correct way as far as I can see to do this type of compare situation. If you were to use "IF" statements and try to capture all posibilities the code would look much different.
    New England
    That looks like a nice clean solution Dave!
    Jan 2006
    Istanbul
    Cool
    Why not using the statement below?
    IF PulseLength > 165 AND PulseLength < 176 THEN
    OutValue=0
    IF PulseLength > 184 OR PulseLength < 192 THEN OutValue=1
  1. Using Nokia LCD
    Last Post: - 3rd May 2018, 05:47
  2. Sony SIRC IR Issue
    By Ryan7777 in forum mel PIC BASIC Pro
    Last Post: - 8th August 2015, 09:10
  3. Write Onewire data toa I2C memory / read ASCI
    By Eugeniu in forum mel PIC BASIC Pro
    Last Post: - 16th November 2008, 20:19
  4. Crystalfontz LCD
    By jman12 in forum mel PIC BASIC Pro
    Last Post: - 9th February 2007, 16:04
  5. Interrupt/timer not really interrupting...
    Last Post: - 22nd May 2005, 23:05
