ADC_CLOCK Question
Results 1 to 4 of 4
    Default ADC_CLOCK Question
    where do the numbers for Define ADC_Clock come from. I have seen a 1, 3, 8. How do I know what to set it to and where do I get this list of numbers? I am using PBP with a 16f876a and a 20 mhz crystal. Thanks in advance.
    Travin77, You need to look in the data sheets for the PIC micro you are using. For instance in the data sheet for the 16F88 bits 7 & 6 of ADCON0 register need to be set to binary equiv. of 3 for the internal RC clock source for the A/D. This is the same as the DEFINE ADC_CLOCK 3 statement.
    Default Adc Clock
    Thanks. I just gave up on it. My sensor was bad anyway. Thanks again.
    Jan 2006
    Istanbul
    Thumbs up
    As stated in Data Sheet:
    bit 7-6 ADCS1:ADCS0: A/D Conversion Clock Select bits
    00 = FOSC/2
    01 = FOSC/8
    10 = FOSC/32
    11 = FRC (clock derived from the internal A/D module RC oscillator)
    If these are complex things to play with then use the following DEFINEs instead:
    For FOSC/2:
    DEFINE ADC_CLOCK 0
    For FOSC/8:
    DEFINE ADC_CLOCK 1
    FOSC/32:
    DEFINE ADC_CLOCK 2
    For A/D RC oscillator:
    DEFINE ADC_CLOCK 3
  1. ADCIN question
    By Greg McFadden in forum General
    Last Post: - 16th September 2008, 02:53
  2. AN Question for "word" variable read The serial port
    By redfoen in forum mel PIC BASIC Pro
    Last Post: - 14th December 2007, 17:39
  3. Remote PIC input question
    By Adrian in forum mel PIC BASIC Pro
    Last Post: - 1st September 2007, 15:44
  4. Question for a math guru
    Last Post: - 22nd November 2006, 09:45
  5. Please answer my first question
    By John_001 in forum Off Topic
    Last Post: - 15th September 2006, 06:49
