Using GPIO.3 as input on 12F629
Results 1 to 3 of 3
    Mar 2005
    Denmark
    Question Using GPIO.3 as input on 12F629
    I would like to use GPIO.3 as an input on the 12F629.
    But how do I do that in the right way?
    Is this the right way?
    @ DEVICE pic16F628, INTRC_OSC_NOCLKOUT, NO_MCLR
    DEFINE OSCCAL_1K 1     ' Load factory value into OSCCAL
    CMCON=7                    ' Turn analog comparators off
    TRISIO = %11001111     ' Set GPIO 0-3 as inputs 5-6 as outputs
    I have to use NO_MCLR right?
    If I look on page 54 in the datasheet, the CONFIG word bit 5 sould be set to 0, does NO_MCLR do that?
    There is a note (note 5) that says: When MCLR is asserted in INTOSC or RC mode , the internal clock oscillator is disabled.
    What dose that mean?
    Kind regards
    Sharky
    *Let's do it*
    At least choose the right processor But anyway, open the m12F629 .INC file in your PBP\INC folder, there you'll se your config fuses.
    So i bet it should look like
    @ DEVICE 12F629, INTRC_OSC_NOCLKOUT, MCLR_OFF
    Mar 2005
    Denmark
    Hi mister_e,
    Dooh, yes of course it's: @DEVICE 12F629
    Thanks!
    Sharky
    *Let's do it*
  1. Input problems with 12F629?
    By achilles03 in forum mel PIC BASIC Pro
    Last Post: - 24th April 2018, 06:25
  2. Sony LanC Program
    By l_gaminde in forum Code Examples
    Last Post: - 25th September 2009, 18:51
  3. 12F629 Strange interupt behavior
    By BGreen in forum mel PIC BASIC Pro
    Last Post: - 25th May 2007, 15:35
  4. Timing input pulses and re-outputting them
    Last Post: - 28th February 2007, 01:50
  5. Input on 12F629
    Last Post: - 16th March 2005, 11:14
