Using pic chips in a noisy electrical environments
Results 1 to 9 of 9
    Aug 2005
    Mat would you explain what you mean by big ground copper?
    Oct 2003
    holland
    I mean, when you look at your circuit board than you see almost everywere copper. ans in between some copper lines which connect the points.
    Normally you see only the copper lines from one point to another and the rest is the material of the circuitboard.
    Now that part the copper is still there and connected to the 0V or gnd.
    If you use dubbelsided printed circuitboards, then do that on both sides.
    Feb 2005
    Kolkata-India
    Default To be precise it is copper pour.
    In any pro PCB design software you will find the option of copper pour. It covers the unused areas with copper with the clearence you provide. Normally you can connect the copper pour to the Ground line. For your reference I am attaching two pictures of one of my PCB. One without copper pour and the other with copper pour.
    Sougata
    Oct 2003
    holland
    Yes, this is what I mean, and if you see still white parts then put the copper there back, and try to connect that to the big parts already there.
    Aug 2005
    Thanks Mat and Sougata. I understand now. I am just an amateur and I really appreciate you guys taking time to help me. I am going to try this on a prototype board that I am working on. Thanks again for the help.
    Sep 2005
    Campbell, CA
    I recently had an application where the power was very noisy. The PIC had its own power and ground planes, and hundreds of microfarads of capacitance. Nothing worked until I decided to feed the PIC power plane from the main power through a Schottky diode (very low Vf type). I have 100uF and lots of .1uF caps on the PIC side of the diode.
    Now, when the power on the "Main" side drops to a low voltage for a few nanoseconds, the PIC runs on the capacitor "battery". The circuit is now perfectly stable, and even though the PIC now only has 4.53V for VCC, it is still above the minimum of 4.2V.
    Charles Linquist
    Charles Linquist
    Hi, Charles
    I also use that solution for a car electronic ignition PIC supply ... and the power Transistor or IGBT is driven through an opto-coupler !!!
    No problem ...
  1. SMS via pic
    By kenandere in forum GSM
    Last Post: - 10th March 2010, 11:00
  2. Selecting PIC chips
    Last Post: - 7th July 2008, 19:55
  3. Electrical noise problem with PIC 16f84
    By Snap in forum General
    Last Post: - 26th September 2007, 10:36
  4. Serial Pic to Pic using HSER
  5. PIC chips, stepper motors and precision
    By Demon in forum General
    Last Post: - 6th February 2005, 17:28
