8 data and parity using HSERIN, HSEROUT
Results 1 to 3 of 3
    Smity42's Avatar
    Smity42 Guest
    Question 8 data and parity using HSERIN, HSEROUT
    Is it possible to set up 8E1 and/or 8O1 (8 data bits, 1 parity bit, 1 stop bit) using the hardware usart on a PIC16F88.
    There is a setting for SERIN2 and SEROUT2 that allows you to use these modes, but I would rather use the HSERIN and HSEROUT commands if possible.
    BTW i have Pro compiler... if it helps.
    Smity42, Use the command DEFINE HSER2_BITS 9 to setup the hardware serial uart for 9 bit transmittions and then use DEFINE HSER2_ODD or HSER2_EVEN to set the parity state. Its all in the manual....
    Smity42's Avatar
    Smity42 Guest
    Hi dave,
    thanks for your help. I was looking at the HTML manual (http://www.melabs.com/resources/pbpmanual/) and it has no mention of the HSER_BITS define at all, and I have no idea where my printed manual has got to. So I checked the PDF one and found it. Thanks muchly
    Martin
  1. AT/PS2 Keybord - PIC Interface?
    By Kamikaze47 in forum Code Examples
    Last Post: - 9th August 2009, 17:10
  2. Reading in Manchester code
    By brid0030 in forum Code Examples
    Last Post: - 10th March 2009, 22:55
  3. Is HSEROUT corrupting bit 7 ?????
    By Robert Wells in forum mel PIC BASIC Pro
    Last Post: - 23rd October 2008, 17:26
  4. Even Parity
    By Andre_Pretorius in forum Serial
    Last Post: - 17th July 2007, 16:48
  5. Debug with parity?
    By cmolson in forum mel PIC BASIC Pro
    Last Post: - 3rd December 2005, 01:23
