Array comparison
Results 1 to 2 of 2
    Default Array comparison
    I have an array that is 12 spaces long. I am trying to compare the second space of the array ( array[1] ) to a numerical value. The array contains ascii characters and numbers ( numbers in this case ). When array[1] is equal to or greater than 6, I want to make a pin go high. This is the code I am using:
    if array[1] >= 6 then
    high portb.7
    When I do this, it makes the pin high no matter what. I know for sure that array[1] is not greater than 6 because I can see what value it is on an lcd. Any ideas as to what I am doing wrong? Thanks for any help.
    Feb 2005
    Kolkata-India
    Default Are you sure that is a number
    Hi there,
    IF you are using
    LCDOUT, array[1]
    and it is displaying 6 on your LCD screen it essensially means that it is definately not a 6 but an ASCII representation of 6 which is decimal 54. So check it out.
    IF you are using
    LCDOUT, DECarray[1]
    then it is a "6" and something else makes your port high. Why not include an else in your IF-ENDIF routine that turns of the bit when it is not greater than 6.
    As I always yell on this forum that a more bit of code is needed. For example how are you transferring values or getting values into an array. If by serial in and hyperterminal then it is definately "ASCII"
    Sougata
    Last Post: - 14th June 2016, 08:55
  2. Simple Array Demo
    By Archangel in forum Code Examples
    Last Post: - 15th February 2010, 05:46
  3. Array values changing
    By MyBuddy in forum mel PIC BASIC Pro
    Last Post: - 30th October 2009, 00:13
  4. Filling pdu array with gps data!
    By camolas in forum mel PIC BASIC Pro
    Last Post: - 4th October 2008, 01:54
  5. RS232 receive an array (packet)
    Last Post: - 12th February 2008, 06:02
