Don't know about NVRAM - but many PICs have on-board EEPROM which is retained when power is off.
Limited erase / write cycles, so if you need to write the data very often the EEPROM may not work for you.
Settings for a chip should be done in EEProm which is on board. If your logging data external NVRAM would be better.
