Tmr1
Results 1 to 8 of 8
Thread: Tmr1
    BobSpencerr's Avatar
    BobSpencerr Guest
    Unhappy Tmr1
    Dear All,
    I am trying to configure a 16f628 to run with an external 32khz watch crystal to create a truely accurate clock. The main chip oscillator is 4mhz adn so I am trying to use the tmr1 interrupt function to allow the chip to sleep between updates of the clock.
    So far, I have had absolutely no luck.
    Can anyone help.
    Expand on what you've posted Bob... how exactly have you connected your 32k crystal to the PIC... is it in place of your 4MHz crystal, therefore your PIC will be runniing at 32k rather than 4Mhz?
    Melanie
    Mar 2006
    The 32khz Xtal is connected to the Tmr1 Timer pins RB6 and RB7 with 33pf caps on each pin to ground.
    The main chip oscillator is 4mhz being driven by a 4 mhz crystal on RA6 and RA7, again with caps to ground.
    Do you have any sample code others may have submitted?
    Jun 2006
    Talking
    ...to allow the chip to sleep between updates of the clock. ...
    It's just THE time to update the clock ... don't you think, Savnik ???
    By the way ... DT_INTS + ELAPSED_INT might be the "couple of the year" ... just need a little SEARCH
    No, Savnik ... not the "couple of the next century" ....
    PS : Holy Grail is here ... : http://www.pbpgroup.com/modules/wfse...hp?articleid=8
    Jun 2006
    No, because my clock today show 13-May-2008
    The post of Melanie is 18th July 2003, 11:49
  1. Simple TMR1 application example needed
    Last Post: - 4th February 2010, 09:52
  2. TMR1 external LP xtal setup check
    By comwarrior in forum mel PIC BASIC Pro
    Last Post: - 13th October 2009, 18:11
  3. Replies: 2
    Last Post: - 7th October 2009, 00:06
  4. Measuring change of frequency with PIC
    By Aussie in forum mel PIC BASIC Pro
    Last Post: - 19th July 2007, 01:47
  5. TMR1 Preset Calculation help
    By Squibcakes in forum mel PIC BASIC Pro
    Last Post: - 2nd December 2005, 00:53
