ultrasonic sensor
Results 1 to 9 of 9
    Dec 2005
    Quote Originally Posted by Melanie
    Measuring an Ultrasonic Receivers signal voltage is a unique approach although I suspect it is not a correct one as I can see many scenarios where this would cause problems.
    The correct method is to measure the TIME between the leading edge of a Transmission Pulse and the leading edge of the Received Pulse. Since sound travels at around 331m/Second (with only slight adjustment for altitude and temperature), it comes to pass that you can achieve a resolution of around 0.331mm/uS. With a bit of decent code, a 4MHz PIC should be able to resolve distances as low as 2cm.
    Has anybody tried using an ultrasonic receiver instead of a PIN diode with an Atmel U2538B, T2526 or T2527 chip? It might simplify processing.
    Dec 2003
    Storrs, Ct.
    Default ultrasonic distance sensor
    I used the following code to test out a SRF-04 Ultrasonic sensor from Acroname with a 16f876 (I think, maybe an f84). I believe it worked fine. Results sent to a serial LCD or to Hyperterminal. I think it's on the lines of what Melanie is suggesting.
    <code>
    DEFINE LOADER_USED 1 'Only required if bootloader used to program PIC
    DEFINE HSER_RCSTA 90h 'setup receive register
    DEFINE HSER_TXSTA 20h 'setup transmit register
    DEFINE HSER_BAUD 2400 'setup baud rate
    'DEFINE HSER_SPBRG 25 'setup baud rate
    ' -----[ Variables ]-------------------------------------------------------
    Dist VAR WORD 'setup variable to hold result of sonar conversion distance
    fire VAR WORD 'setup variable to hold result of flame sensor
    speed VAR WORD 'setup variable to hold result of next sensor
    fire = 18 'dummy number for now
    speed = 27 'dummy number for now
    ' -----[ Initialization ]--------------------------------------------------
    portsetup:
    PORTC = %00000000 ' all outputs off to start
    TRISC = %00010000 ' All of Port c is outputs except RC4
    ' -----[ Main Code ]-------------------------------------------------------
    'Pause 10 'settle in time(may not be needed)
    GoSub sr_sonar 'goto sonar code
    GoSub hyperview
    GoSub lcdview 'print on LCD and Hyperterminal
    GoTo main 'Repeat forever
    sr_sonar:
    PORTC.4 = 0 'Be sure RC4 is low
    PulsOut PORTC.4,2 ' 10us init pulse
    PulsIn PORTC.5,1,Dist ' measure echo time
    Dist = Dist / 15 ' convert to inches
    Pause 100
    hyperview:
    HSerout ["Distance to Object = ", DEC dist,13,10]
    Pause 250
    HSerout ["Magnitude of flame = ", DEC fire,13,10] 'output data to hyperterminal
    Pause 250
    Pause 250
    HSerout ["Speed of Travel = ", DEC speed,13,10]
    lcdview
    SerOut PORTB.6,0,[254,1] 'clear LCD screen
    Pause 40
    SerOut PORTB.6,8,[254,134,"FIRE"] 'List outputs to LCD
    SerOut PORTB.6,8,[254,199,#fire]
    SerOut PORTB.6,8,[254,128,"DATA"]
    SerOut PORTB.6,8,[254,193,#Dist]
    SerOut PORTB.6,8,[254,140,"SPED"]
    SerOut PORTB.6,8,[254,204,#speed]
    Pause 500
    </code>
    It's been a few years since I've tried it. Hope it helps.
    johor,Malaysia
    still problem
    i add this program in my code
    for transmit the signal
    PORTA.4 = 0
    PulsOut PORTA.4,2
    for recieve i use amplifier for increase the voltage.
    but stilll cant function.
    can some one help me..
    USA - Arizona
    Wink
    I think you would be better off understanding the basic principle of SONAR detection before just launching at this. I believe your receive configuration is missing some bias on the Q2 & Q3 transistor (or you have some resistors values that are just too big).
    Take a look at this, it is the simplest approach. Take time to read it, don't just copy and paste the schematic and code (or you'll be back here or 'there' asking more of the same questions).
    Jul 2005
    Getting any circuit like this to work can be a HUGE effort, as you have analog, digital and code issues all running together, and usually, unless everything works, nothing works.
    So take it in steps... and do please tell me you have an osciloscope. Without an oscilloscope there isn't much you can do with a non-working circuit but say a prayer.
    So first, make sure the transmitter is getting a pulse train at 40 KHz. If not, make it so. Once you have that, look at what the reveiver is doing. Q2 collector should show you a burst of 40KHz pulses that are the echo; trigger the scope on the transmit burst and see how long the return burst takes.
    Once you see that, you can adjust one of the pots (R17, R18 and R190 so it triggers on the "meat" of this burst. I don't know why there are 3 comparitors there, only one is needed to tell when the return happens.
    I have done a similar circuit, I did not use comparitors, just a transistor between my receive amp to "square off" the return signal and use that to trigger an interupt, the ISR then read a timer to determin time of flight. Using interupts isn't essential but would be a bit more accurate then polling the port pins.
    johor,Malaysia
    thank
    now i understand
    how i can pause 10us for transmit the signal.
    what cristal oscletor.
    realy need help
  1. Need a cheap touch sensor idea.. here it is
    By mister_e in forum Code Examples
    Last Post: - 16th April 2016, 23:42
  2. Ultrasonic distance sensor with PIC16F84A
    Last Post: - 29th June 2009, 10:01
  3. PICBASIC PRO-coding for wireless sensor node
    By syazila in forum mel PIC BASIC Pro
    Last Post: - 10th February 2009, 01:05
  4. Water Level Detection using Ultrasonic Sensor
    By Balachandar in forum mel PIC BASIC Pro
    Last Post: - 12th November 2007, 05:59
  5. sensor ultrasonic 8051&PIC
    By hd_uni_pro in forum Schematics
    Last Post: - 13th September 2006, 13:58
