12c508a Device Config. And Burning Issues
Results 1 to 5 of 5
    There is a 12F508... you can erase and reprogram that as many times as you want. Then, with the code working, you can burn your 12C508's safe in the knowledge that they're not going to be wasted.
    As you said it works with F508 but not with C508... i may bet on your programmer but unsure. Just do some test here with both of my programmer.. no problem. ARRGH!
  1. Burning CONFIG fuses
    By hamster in forum mel PIC BASIC Pro
    Last Post: - 11th February 2006, 20:56
