Help with, SEROUT
Results 1 to 7 of 7
    Kimto's Avatar
    Kimto Guest
    Default Reply
    Ok, there is a big difference between "mel" and comfile. But now I now, what compiler I should have bought. I thought the code should be the same, when they use the same microcontroller.
    Thanks for the reply.
    Do you have a Compiler currently? If you've bought something other than the MeLabs product then this isn't the place for you because the program syntax and functions will almost certainly be different and folks here will probably not be able to help. There's now a lot of compilers out for the PIC, some good, some bad and some really awful. I can't comment on how good Comfile is versus MeLabs because I don't know and have no experience of the product.
    If you've already spent money on another product, then firstly you should consider a damage limitation excercise and give the other product a go (and see if they have a support forum) before thinking about buying something else. But, when considering MeLabs, it's been around for a long time, produces nice code, and it works - even for newbies! *smiles*
    Last Post: - 8th March 2010, 21:58
  2. Serout to serial servo
    By azmax100 in forum mel PIC BASIC Pro
    Last Post: - 12th August 2009, 17:46
    Last Post: - 13th December 2008, 18:11
  4. Keypad unlock (as in garage door possibly)
    By Fred in forum Code Examples
    Last Post: - 2nd April 2006, 05:26
  5. Replies: 11
    Last Post: - 13th July 2005, 20:26
