LCD(pic16f688)
Results 1 to 2 of 2
Thread: LCD(pic16f688)
    tarr's Avatar
    tarr Guest
    Question LCD(pic16f688)
    hey
    i am program pic16f688 to receive signal from the gyro (MG1101). i am using LAB-x4 development board. iam also using pic basic pro compiler. i sucessfully compile my program but not seeing anything thing appear on the LCD. for example i wanted for "gyro ready" or "hold still" to appear. could anyone help me out how to use the SEROUT command to have my pic running.below is my code.
    '* Name : UNTITLED.BAS *
    '* Author : [benedict tarr] *
    '* Notice : Copyright (c) 2006 [select VIEW...EDITOR OPTIONS] *
    '* : All Rights Reserved *
    '* Date : 3/22/2006 *
    '* Version : 1.0 *
    '* Notes : *
    include "modedefs.bas"
    Define LCD_DREG PORTA
    Define LCD_DBIT 4
    Define LCD_RSREG PORTA
    Define LCD_RSBIT 0
    Define LCD_EREG PORTB
    Define LCD_EBIT 1
    LCD var PORTA.1
    SCL VAR PORTC.1
    SDA VAR PORTC.0
    ' EEPROM control = $A0
    ' Gyro control = $AE
    address VAR Byte
    x VAR BYTE
    calibration VAR BYTE[16]
    ar VAR WORD
    br VAR WORD
    ar_ave vAR WORD
    br_ave VAR WORD
    ADCON1 = 7 ' Set PORTA and PORTE to digital
    Low PORTB.2 ' LCD R/W line low (W)
    Pause 500 ' Wait for LCD and gyro to start up
    SEROUT LCD, T2400, [$fe, 1] ' Clear screen
    serout LCD, T2400, ["Begin Initialization"] ' Display message
    'Read 15 calibration bytes and control register from EEPROM
    address = 0
    I2CREAD SDA, SCL, $A0, address, [STR calibration\16], i2cerr
    ' Set INIT and Power Mode 001 in control register value
    calibration[$0F] = %01000001
    ' Write 15 calibration bytes and control register to gyro
    I2CWRITE SDA, SCL, $AE, address, [STR calibration\16], i2cerr
    PAUSE 10 ' needed??
    serout LCD, T2400,["Waiting"] ' Message to user
    ' Begin polling GRNR bit
    waitGRNR:
    address = $08
    I2CREAD SDA, SCL, $AE, address, [x], i2cerr
    If x.1 = 1 Then waitGRNR ' If GRNR, continue polling
    ' GRNR is clear, display message and pause to let stabilize
    serout LCD, T2400,["Gyro Ready", $FE, $C0, "Hold Still..."]
    PAUSE 3000
    ' Take an average reading (64 samples) while gyro is motionless
    ar_ave = 0
    br_ave = 0
    address = 0
    For x = 0 to 63
    pause 1
    I2CREAD SDA, SCL, $AE, address, [ar.byte1, ar.byte0, br.byte1, br.byte0], i2cerr
    ar_ave = ar_ave + (ar >> 6)
    br_ave = br_ave + (br >> 6)
    Next x
    ar_ave = (ar_ave >> 6)
    br_ave = (br_ave >> 6)
    LCDOUT $FE, 1 ' Clear the display
    loop:
    ' Get word values from gyro
    ' Scale the values for readability (divide by 64), subtract from average,
    ' and display signed values as yaw and pitch
    serout LCD, T2400,["Yaw: "], SDEC (ar_ave - (ar >> 6)),[" "],_
    serout LCD, T2400,[$FE, $C0, "Pitch: "], SDEC (br_ave - (br >> 6)),[ " "]
    Pause 100 ' Do it ten times a second
    goto loop
    i2cerr:
    serout LCD, T2400,[$FE, 1, "I2C Error"]
    STOP
    Hi tarr,
    Couple of possibilities. The 16F688 has comparators, and individually selectable A/D inputs, so you need to ...
    CMCON0 = 7
    ANSEL = 0
    to be able to use PORTA as digital. ADCON1=7 doesn't work here.
    Also, the LAB-X4 has several jumpers, to select whether you are using the Parallel or Serial interface to the LCD.
    For the Serial interface you should have
    JP7-12 Open
    JP3 - Installed
    Once you turn off the analog ports you should also see the data sent to the LCD on the RS-232 port. (If JP13 is installed)
    When using the serial interface, you don't need the LCD DEFINE's.
    HTH,
      Darrel
