YEEK! i use MicroCode Studio but never got this message.. as far as i remind.
How about the usual remove everything then re-install?
What about if you use MPASM instead as compiler?
If PICBasic is erroring with an Out of memory message, then it'll do so regardless if it is compiling for the default PM or the alternative MPASM.
Technically MPASM is an Assembler. PICBasic is the Compiler, the end product being Microchip Assembler which is then processed by either PM or MPASM to produce your final HEX.
If all else fails, compile it in a DOS window outside of Microcode per MeLabs instructions.
Melanie,
I compiled it in a Dos and worked very well.
Thanks.
Select VIEW...COMPILE AND PROGRAM OPTIONS, the the asembler tab. Manually point it to MPASMWIN.EXE. If you are still having problems, you need to manually edit the registry and delete
HKEY_CURRENT_USER\Software\MecaniqueUK\MicroCodeSt udioPlus\Assembler
OR
HKEY_CURRENT_USER\Software\MecaniqueUK\MicroCodeSt udio\Assembler
if you are using the free version. After that, all should work well from within MCS
