Error 102
Results 1 to 9 of 9
Thread: Error 102
    Mar 2006
    Brasil
    Default Error 102
    Melanie,
    How can I config the microcode to use this,
    PBPW -p16F876A myfile
    Mauricio Ortega
    I don't use Microcode - somebody else want to address this?
    YEEK! i use MicroCode Studio but never got this message.. as far as i remind.
    How about the usual remove everything then re-install?
    What about if you use MPASM instead as compiler?
    Mar 2006
    Brasil
    Default Error 102
    Mister_e,
    I'll try this...
    Mauricio Ortega
    If PICBasic is erroring with an Out of memory message, then it'll do so regardless if it is compiling for the default PM or the alternative MPASM.
    Technically MPASM is an Assembler. PICBasic is the Compiler, the end product being Microchip Assembler which is then processed by either PM or MPASM to produce your final HEX.
    If all else fails, compile it in a DOS window outside of Microcode per MeLabs instructions.
    Mar 2006
    Brasil
    Default Error 102
    Melanie,
    I compiled it in a Dos and worked very well.
    Thanks.
    Feb 2005
    Saltburn by the Sea
    Select VIEW...COMPILE AND PROGRAM OPTIONS, the the asembler tab. Manually point it to MPASMWIN.EXE. If you are still having problems, you need to manually edit the registry and delete
    HKEY_CURRENT_USER\Software\MecaniqueUK\MicroCodeSt udioPlus\Assembler
    OR
    HKEY_CURRENT_USER\Software\MecaniqueUK\MicroCodeSt udio\Assembler
    if you are using the free version. After that, all should work well from within MCS
