interrupt problem....need help urgently
Results 1 to 3 of 3
    johnson's Avatar
    johnson Guest
    Default interrupt problem....need help urgently
    dear all,
    I have some problem regarding using an interrupt. When an external interrupt occurs, I want the program counter to jump to the specific label instead of continue from the code that interrupt occured. Any suggestion?
    I wrote this in pic basic but it does not seem to be correct:
    disable
    isr:
    if (mode<=maxmode) then
    mode=mode+1
    intcon.1=0
    pause 50
    enable
    the code shows that whenever interrupt occur, after operation the program should jump to main instead of continue the code.
    thanks in advance :>
    Your example is NOT correct.
    When you jump to a Interrupt Service Routine with the ON INTERRUPT statement like so...
    ON INTERRUPT GOTO ISR
    you must treat this routine as if it was a subroutine, EXCEPT that with a subroutine it is exited with a RETURN, an Interrupt Service Routine MUST be exited with a RESUME.
    Optionally, the RESUME can have a label to jump to as in...
    RESUME ContinueFromHere
    or in your example you would have...
    RESUME Main
    but if the label is omitted, then you will resume from the point the program was 'interrupted'.
    So, if you specifically need to resume from a specific point, you do so by adding a label to the end of the RESUME statement as per my example above.
    If you fail to use a RESUME when exiting your ISR, then eventually you will have a stack overflow with unpredicatable results. Remember, with most PICs, your stack is only four levels deep... that means a TOTAL of FOUR subroutines and/or interrupts at any one point in time.
    Melanie
    johnson's Avatar
    johnson Guest
    thanks a lot:>
  1. Problem with Interrupt on PIC18F4620 PORTB
    By rookie in forum Off Topic
    Last Post: - 22nd March 2007, 01:34
  2. Problem with PBP interrupt and Serin, please help
    By rgregor in forum mel PIC BASIC
    Last Post: - 22nd August 2006, 19:02
  3. Interrupt Problem
    Last Post: - 16th November 2005, 20:58
  4. Interrupt stack overflow problem with Resume {label}
    By Yuantu Huang in forum mel PIC BASIC Pro
    Last Post: - 3rd May 2005, 01:17
    Last Post: - 6th March 2005, 01:07
