how to know servo position on lcd?
Results 1 to 4 of 4
    New England
    Along the same lines as Jim suggested - maybe hook up an external POT to the servo shaft?
    Arch
    Jun 2005
    Wisconsin
    The answer really depends on what your trying to do.
    Depending on the application an optical or mechancial encoder may be a better choice, in place of the servo. If your trying to "teach" the pic a servo postion and then have the pic repeat that later you may want to use the servo (unmodified) in combination with an encoder wheel to sense location.
    Finally you may want to switch to a stepper which you can read from in one mode and send to a location in another.
  1. More Servo Woes
    By chrisshortys in forum mel PIC BASIC Pro
    Last Post: - 13th May 2009, 09:40
  2. Play with LCD on PICDEM
    Last Post: - 22nd August 2008, 17:56
  3. Servo does not move
    By ruijc in forum General
    Last Post: - 12th November 2007, 20:14
  5. LCD will not start
