how to know servo position on lcd?
Results 1 to 4 of 4
    macx75's Avatar
    macx75 Guest
    Default how to know servo position on lcd?
    Hi all
    How do i move the servo by hand and know its position on lcd.? is there any command in picbasic?
    macx
    Sep 2005
    Dayton, Ohio
    You would have to modify the servo so you can read the internal potentiometer. You will have to at least open the servo up and get some wires onto the potentiometer's pins.
    Then use the ADCIN or POT command to read the position of the potentiometer.
    But in this case the servo itself just acts as a very complex "knob".
    Jim Robertson
    "MilesTag" DIY Lasertag
    www.lasertagparts.com/mtdesign.htm
    Dayton, Ohio
    New England
    Along the same lines as Jim suggested - maybe hook up an external POT to the servo shaft?
    Arch
    Jun 2005
    Wisconsin
    The answer really depends on what your trying to do.
    Depending on the application an optical or mechancial encoder may be a better choice, in place of the servo. If your trying to "teach" the pic a servo postion and then have the pic repeat that later you may want to use the servo (unmodified) in combination with an encoder wheel to sense location.
    Finally you may want to switch to a stepper which you can read from in one mode and send to a location in another.
  1. More Servo Woes
    By chrisshortys in forum mel PIC BASIC Pro
    Last Post: - 13th May 2009, 08:40
  2. Play with LCD on PICDEM
  3. Servo does not move
    By ruijc in forum General
    Last Post: - 12th November 2007, 19:14
  5. LCD will not start
