Reset problem
Results 1 to 23 of 23
Thread: Reset problem
    Jan 2006
    Istanbul
    Thumbs up
    Quote Originally Posted by Acetronics
    It's easy to understand why : try the "turkish" toilets, and you'll discover how elders were trying to wash their feet during "uptide".
    Yes, they were at least trying to wash; and started doing it more then 1000 years ago Alain!
    If you wanna keep a girl home, it's time to learn the difference between "eau de toilette" and "parfum"...
    Quote Originally Posted by mister_e
    ahhh this is the reason why!! mmm thanks Alain!
    I have to admit and agree with Steve . I did not know that fact Alain. I will get back to you if that does not work. Thanks for the tip.
    Feb 2004
    Germany
    And if the girl still browns out or resets, put a POT on her.
    regards
    Ralph
    Talking
    Or simply flush her!
    Jan 2006
    Istanbul
    Thumbs up
    Quote Originally Posted by NavMicroSystems
    I used BOD_ON and had a loooong I/O connection with short pauses after each reset.
    However, after fifth or sixth reset which I could not count quite precisely, it becomes quite difficult to keep the output port HIGH as the PSU gets quite hot and supply voltage drops dramatically. I did not observe this at the input port as it kept accepting the incoming packets!
    Ohh almost forgot;
    The result: “If you wanna keep a girl home”, in addition to Alain’s suggestion above, having a good PSU with optional internal cooling fan could also help.
    Any other suggestions for longer I/O connections?
  1. Pic reset and following lock up problem
    By zerosvarka in forum General
    Last Post: - 17th June 2009, 20:03
  2. LCD Reset Problem
    By Bill Legge in forum mel PIC BASIC Pro
    Last Post: - 24th February 2009, 08:55
  3. process hung problem + self reset
    By eng.alamin in forum mel PIC BASIC Pro
    Last Post: - 31st October 2008, 16:22
  4. USART Problem , but don't know where, in pc? or in PIC?
    Last Post: - 15th July 2007, 08:12
  5. PIC problem, ways to do reset
    By lab310 in forum mel PIC BASIC Pro
    Last Post: - 26th May 2005, 14:31
