Reset problem
Results 1 to 23 of 23
Thread: Reset problem
    Jan 2006
    Istanbul
    Thumbs up
    Here is something to add as a solution for those who still have reset problems.
    1: Use 47K trimpot on MCLR pin.
    2: Adjust the trimpot untill the resetting stops. Requires hard reset after each change.
    3: Remove the trimpot, measure the resistance value, and use a resistor at the same value.
    4: Done.
    BOD_OFF did not work for me but a trimpot at MCLR pin solved the problem.
    GoTo 1
    I've never designed a circuit that, where MCLR required connecting, nailing it directly to Vdd was a problem (excluding of course ICSP applications). If you have got so much crap coming down your Supply line that trips out your PIC, then it's time you seriously thought about redesigning your Supply circuit. Because if you go and smooth-out MCLR on it's own, the rest of your PIC is still getting a rubbish supply... then that's going to affect Voltage References, Comparators, ADC's, the point at which your I/Os switch etc etc.
    Wink Quiet supplies ... ahhhhh !!!!
    Hi, Leonel
    One simple solution is to bring the 5 v to the PIC ( only the PIC ...) through a diode ( Low drop Schottky if required ) and havind a BIG capacitor ( say 470 - 1000µF ) connected to the Cathode. This doesn't keep you from having the usual 10µF and .1µF decoupling caps.
    This will filter spikes, and allow powering the PIC if supply voltage falls too low.
    This also permits to shut down all peripheral components BEFORE the Pic goes to bed ... always having known peripheral states at power off.
    Hi, Mel
    When you design an Electronic Ignition or a High Voltage device from a battery , you DO NOT have the choice for a "nice and clean" supply !!! ...
    I disagree Alain
    The electronics that you design-in between the PIC and the incomming Power Source, be it vehicular or Battery sourced always ensures the PICs supply is clean. If it's not, then you have a disaster waiting to happen - the TGV will derail, the Président de la République Française will resign, the Government will fall, the Guilotine will be taken out of storage and sharpened - and it will all be your fault.
    Talking Politics ...
    Quote Originally Posted by Melanie
    the Président de la République Française will resign, the Government will fall, .
    Do you REALLY think it would be a disaster ???
    It's evident you don't live here !!! And you do not know anything about Jacques ( Old friend of mine ... )
    PS: aboard your car, you take a diesel generator for the electronics to work ??? ...
    Aboard my car I design-in circuitry between the Supply and the PIC so that the PICs supply is clean. I ensure the raw supply tracks and components are away from the clean-side tracks and components. I ensure the PCB is well designed to absorb induced transients harmlessly. I ensure all I/O's (Analogue or Digital) that go off my PCB are filtered accordingly. But, most importantly, I ensure my public liability insurance is paid-up.
    Jacques is a Gaullist... it is well known they prefer Atmel...
    I didn't really want to mention it but... recent Reuters photograph shows rioting in Paris street after PIC controlled model airplane slams into street toilet on Rue de Sevres... Journal Le Monde quotes "the devastating methane explosion scattered toilet paper across a wide area and flash-backed down the sewers starting fires in several city suburbs"... see... it's all caused by bad PSU design.
    Talking Pfffff .... It's end of April !!!
    > Sorry ... he's just an opportunist ... in 68' De Gaulle had called the army tanks ( to be precise they were waiting in Rambouillet ... 50 kms from Paris ) ; here, for the CPE Jacques just lost his pair of trousers ...
    Always remember being Gaullist means being a real man ...
    it is well known they prefer Atmel ... ( ?????? )
    I'd rather think "THE" model airplane was slammed down due to a huge methane release into the street toilets.
    Those toilets vents surely could not bear the induced internal overpressure.
    But I know you're joking : Have you ever seen any toilet paper available in our country street toilets ???
    Us, We do not have the "Times" to read ...
    Cheers
    Jan 2006
    Istanbul
    Thumbs up The problem is not with voltage drops.
    Here is an experience for free.
    - Seven 24V/1A motors are connected to power supply along with PIC.
    - PIC drives tiny relays directly, pulls 23mA, and tiny relays drive 24V relays for motor loads.
    - "Sometimes", PIC resets, but not due to the drop in supply voltage. Pls see below.
    1. I used separate power supply for PIC. = No change.
    2. I used battery only for PIC. = No change
    3. I used BOD_ON and OFF and got crazy around its configs. = No change
    4. I used forum search, online search, data sheets, the other ones, all the other other ones, and yes those too. = no change
    5. Finally, I used a trimpot on MCLR pin, as mentioned above, and fixed the problem adjusting it.
    6. No more reset.
    Even though once there was no connection between PIC circuit and motors (separate power supply), I still had reset issue.
    Now, motors and PIC (BOD_ON) are on the same power supply, no reset occurs.
    Meanwhile, BOD_OFF creates LCD problems while it is not supposed to.
  1. Pic reset and following lock up problem
    By zerosvarka in forum General
    Last Post: - 17th June 2009, 20:03
  2. LCD Reset Problem
    By Bill Legge in forum mel PIC BASIC Pro
    Last Post: - 24th February 2009, 08:55
  3. process hung problem + self reset
    By eng.alamin in forum mel PIC BASIC Pro
    Last Post: - 31st October 2008, 16:22
  4. USART Problem , but don't know where, in pc? or in PIC?
    Last Post: - 15th July 2007, 08:12
  5. PIC problem, ways to do reset
    By lab310 in forum mel PIC BASIC Pro
    Last Post: - 26th May 2005, 14:31
