16F628A Serin timeout and Timer1
Results 1 to 6 of 6
    Rubicon's Avatar
    Rubicon Guest
    Default 16F628A Serin timeout and Timer1
    Hello,
    I'm hoping someone can point me in the right direction here.
    PIC16F628A
    4MHz crystal
    Battery powered
    At the moment I have a program that basically naps most of the time over approx 1.5 seconds then awakens to power a receiver to check RB0 for a qualifier byte and match the following byte against a constant. Every cycle it increments a word size counter that in turn increments another byte size counter to exend the overall time-count to three days. Every so many cycles it also checks the PIC battery. After three days the program shuts-down. This seemed O.K. but with a timeout on the Serin as long as the receivers picking something up either modulated or random noise the timeout doesn't expire and the count goes out the door. The Serin timeout not timing out isn't an overly bad thing in that the receiver PIC has to get in sync with the transmitters signal but a constant source of random noise could keep it forever active.
    I want to have the WDT on for the Nap command as it's battery powered so after fumbling through the datasheet and application notes my confused mind asks for help on the timers.
    I don't really know what to do to ensure an accurate and by accurate I mean a +- 1 minute three day overall time count with the Serin timeout but as I type this I can see from an App-note that I could keep the WDT on with Timer1 in Asynchronous Counter Mode and using an external 32.768 oscillator (prescale of 2 for 4 seconds) have an over-flow of the TMR1 register cause an Overflow Interrupt and an interrupt service routine can make sure to turn off power to the receiver (if it's still on from the failed Serin timeout) and increment the counters for the three day overall timeout and battery check.
    Does this sound about right? If not what do you suggest? I know it's certainly easier for me to type out than to do as I haven't had to do anything like it before. Any pointers in the right direction greatly appreciated as it makes searching the archive easier when you know what to look for.
    Andrew.
    Dec 2003
    Wichita KS
    Hello Andrew,
    I am not sure if I fully understand your problem, but let me throw this out to you...
    The SerIn has two things that can help you...
    The Wait until and the timeout.
    I am assuming that the ["A"] (wait until "A" is received, then get the next character) is causing your probem.
    To help get rid of noise, you need to ground the pin with a resister.
    The timeout can be pointed to the place you want to go if no signal is received.
    Serin InputPin, T300, 500, Label,["A"],DataStorage
    500 millisecond timeout and goto Label.
    if ok, put data in DataStorage and continue on.
    What I am not sure about, is if Serin is in receive mode, and is receiving data (good or bad) whether that 500 milliseconds will operate or not. I have not tested it, and I didn't see it in the manual. But I want to assume it is operating.
    Are we on the same page?
    Dwayne
    Ability to Fly:
    Pilots that are Flying:
    Rubicon's Avatar
    Rubicon Guest
    Dwyane
    Thanks for the reply and sorry for my lack of clarity. I really must post when I'm fresh and not so late at night.
    I have the Serin wait and the timeout with a pullup resistor and they work fine with the exception that when the receiver is in fact receiving something the timeout fails. I understand that this is just how it is when using the timeout in Serin. Its essentially the same as if you don't have a pull-up/pull-down resistor to eliminate noise - the transducer line/power supply/component noise with high opamp amplification keeps retriggering the timeout.
    SERIN PORTB.0,T300,200,NOSERIN,[CODE],B9
    As the receiver is ultrasonic (currently using a 40Khz transducer) I've found that there are many things that emit ultrasonics at or close to that frequency, enough anyway to keep the PIC Serin timeout retriggering. For instance a previous computers power supply two rooms away from the reveiver kept its Receive Indicator LED flickering and the timeout from working. An additional problem is that a transducer will resonate most easily at a particular frequency, 40kHz for example but it'll also resonate at other frequencies just not as easily - a good cause for me to investigate bandpass filters!
    This is why I'm after a way other than the program cycle to keep a time count and to turn the receiver off to save battery power when stuck in the Serin timeout.
    Do you think the Timer1 part of my first post is a viable option?
    Andrew.
    Hangover, Germany
    Lightbulb
    Hello,
    forget the timeout-option in "serin" when you receive rf-transmissions.
    I've build it like this:
    I use Timer1 to measure a timelimit.
    So, start Timer1,
    Repeat receive 1 character trough serin,
    if the character is your lead-in receive the rest,
    until timer1 ends.
    go sleep....
    It may be necessary to slow down the transmitter by using DEFINE CHAR_PACING 1000 because you are using slow software rather than fast hardware!
    For me it it not necessary to receive each transmission!
    Rubicon's Avatar
    Rubicon Guest
    Thankyou all for your help.
    As the transmitter is only sending the qualifier byte and a single code byte over and over at 300bps I'll drop the Serin timeout and give the Serin Timer1 timeout option a go this weekend.
    Once again thanks.
    Andrew.
    Hangover, Germany
    Wink
    Think about some leading bytes ($55) in order to syncronize the receiver...
  1. rfPIC Serin problem
    By gavo in forum mel PIC BASIC Pro
    Last Post: - 11th March 2008, 18:52
