PIC18f4220
Results 1 to 12 of 12
Thread: PIC18f4220
    Mar 2006
    Have you seen this?
    http://www.melabs.com/support/cap_mod.htm
    I've also had some intermittent problems with the serial programmer and 18Fxxxx parts. I just ran across this note the other day and haven't had a chance to try it yet. A shorter cable to the socket also seems to help.
    Sep 2003
    Vermont
    I've found that too much capacitance on the B+ line will cause errors with the serial programmer. Powering up the circuit may help. Likewise, if there are any loads on the programming pins of more than a mil, the programmer will read an error. If you have a pinned version, try programming by itself first as a loose part. If that works, then it is a circuit level issue.
    A large, powerful magnet wrapped in a layer of tin foil held about an inch above the chip while programming, may help, but be sure there are no cats in the room(or wet them down) due to static EMD problems. The last solution will work only on today's date.
    Hope some of this helps,
    Ron
    jcullins's Avatar
    jcullins Guest
    Default Pic18f4220
    Thanks Guy,
    I will try the .1 however I am programing DIP parts by incerting them in the programer and not using the ISP plug.
    I am also using the wall wart. It programs the 16 series very well.
    I will let you know if it works
    Jim
    jcullins's Avatar
    jcullins Guest
    Default PIC18f4220
    Thanks a bunch guys
    The cap and the software patch fixed eveything.
    Thanks for you help
    Jim
