I forgot to add I am using
Pic Basic Pro ver 2.46
MeProg ver 3.3
micro studio plus 2.3
MeProg ver 3.3
Is there a MCSP 2.3 version?
On their site is only 2.2.1.1
Yes, you should be able to down load it.
Have you programmed the PIC18f4220 ?
I have an example file form MELabs that compiles
but when I try to program it it comes up with "code error at 0008"
I am wondering if it is my 40 pin ZIF socket on my programmer.
Is there one just for the 18f series . Mine is the one I have used
with the pic16f877 chips.
Jim
Is there anyone out there using this chip ?
I don't seem to get a response from anyone.
I think my problem is with the assembler MPASM but not having used it
before I don't know.
I compile with PBP it is OK
assemble with MPASM OK
try to program with the MELabs serial programmer and it give this error
code programing error at 0000
or somethin like that.
Is this a set up problem?
Jim
Normally all Program memory location are default $FFFF (nop). So you can check your PIC if it reads okay. If it reads $0000 then its your programmer. What a programmer does is dump the hex files in the prog. memory locations and just verifies it while/after programming. In most cases if your first location is not being programmed then your programmer has some communication error with the PIC. Even parasitic capacitance on the data and clock lines make it worse.
Sougata
jcullins,
I do not use the EPIC so I cannot say - however, from MELabs website
http://www.melabs.com/support/epicfixs.htm
snip ....
#1 Most Encountered Problem - Power Supply
The most common cause of programming problems is low power supply voltage. We highly recommend the use of an AC Adapter. Batteries become depleted very quickly, causing program errors ("Code Programming Error at 0000").
... end snip
Good Luck,
Paul Borgmeier
Salt Lake City, Utah
USA
The programmer works fine with the PBP compilier. I program the 16f series all the time with no problem. But it shifts over to the Mchips assembler.
I assembles with no errors but just want program.
Thanks for you help guys.
Jim
