send incomming msg (SMS) to VB
Results 1 to 20 of 20
Threaded View
  1. #2
    Mar 2006
    You don't need to use a PIC to interface your cell to your PC, you just need a data cable and program the computer to listen on its serial port for AT commands and responses which the cell phone uses to communicate. When a cell phone receives a SMS, it can be set to alert an external device (such as your computer) by sending a serial message called an AT command. You then program your computer to send the correct commands to access the bank in which the message was stored in.
    here's an example of what the communication would look like:
    (from cell phone): +CMTI: "ME",27
    (from computer): at+cmgr=27
    (from cell phone): +CMGR: "REC UNREAD","+15551234567","John Doe","05/10/18,23:21:45-20"
    Hello World
    the break down:
    when a cell phone receives an SMS, it sends an AT response of "CMTI ME, 27". The ME means it was stored in memory in storage bank number 27. Your computer must then access this bank by sending "AT+CMGR=27", the cell phone then responds with the message. You can test all of this out without even programming anything, just connect your cell phone to your serial port and then open up a serial terminal emulator (such as Hyperterm for Windows).
    You can interface your cell phone to a PIC using serial communication. It is possible to directly interface the pins to the cell phone since they are both of TTL voltage RS-232 (the cell phone actually uses 3v while the PIC uses 5v, but I haven't had any problems).
    I hope that helps you get started.
  1. Active low input?
    By CosMecc in forum mel PIC BASIC Pro
    Last Post: - 8th August 2010, 20:31
  2. Please send me a SMS program
    By hjcool in forum GSM
    Last Post: - 17th June 2009, 10:33
  3. how to send and receive sms using vb?
    By shyhigh2002 in forum Off Topic
    Last Post: - 1st April 2009, 09:18
  4. Replies: 0
    Last Post: - 1st September 2008, 07:03
  5. sms send sht11 pic16f876 nokia 6210
    By elektoro2009 in forum GSM
    Last Post: - 9th June 2008, 08:57
