ICD Problems
Results 1 to 3 of 3
Thread: ICD Problems
    Ohio
    Question ICD Problems
    I built the recommended circuit that uses the Max 232CPE chip to communicate with a PIC 18F452 micro using ICD. When I run the sample program ‘Sort.bas’ that comes with MicroCode Studio Plus, I get a communications error. I rechecked my circuit and found no mistakes. The next thing I tried was making a very simple program that consisted of the line ‘HIGH PORTA.1’. When I compiled this program using ICD Compile the pin was floating and no 5 volts was seen. When I recompiled this program using the Standard Compile, the pin showed 5 volts. Does anybody have any ideas on what may be the problem?
    Mark
    Do you have the MCS+ or the Free version?
    Did you use ICD_Compile/Program button
    http://www.rentron.com/PicBasic/MCS_X3.htm
    How about your code?
    Any line who disable the Analog stuff on PORTA?
    Ohio
    I think I found my problem. It had to do with the bootloader.
    Mark
  1. ICD, ICSP and Picbasic Pro
    By mwhatley in forum mel PIC BASIC Pro
    Last Post: - 8th August 2024, 21:42
  2. DT Interupts and ICD?
    By ShaneMichael in forum mel PIC BASIC Pro
    Last Post: - 14th November 2009, 03:02
  3. ICD Woes
    By spad13m in forum mel PIC BASIC Pro
    Last Post: - 14th February 2008, 06:56
  4. Another MSCP ICD question
    By keithdoxey in forum mel PIC BASIC Pro
    Last Post: - 31st July 2006, 01:07
  5. Problems with MicroCode Studio ICD
    By Muzza in forum mel PIC BASIC Pro
    Last Post: - 5th July 2006, 03:37
