RH/Temp Sensor Example Code
Results 1 to 8 of 8
    Hi Christopher,
    I haven't tested with this one for accuracy, but it's one of the easiest to use RH/temp sensors I've seen in a while.
    This one has an onboard processor that sends RH & temp out in standard ASCII format. No need for anything analog. It's real simple to use.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    New Jersey
    Bruce,
    I've ordered three temp sensors, two digital and one analog; they should be here tomorrow. I have some additional questions about your code.
    1. I am using the USART port on the PIC for something else so I am pretty sure I can use the temp sensor on another pin for serout/serin but does the code have to be manipulated a lot? Instead of writing:
    HSEROUT ["RH=",TEMP(1),TEMP(2),TEMP(3),TEMP(4),"% : "]
    Can I write
    Serout2 portb.1, 396, ["RH=",TEMP(1),TEMP(2),TEMP(3),TEMP(4),"% : "]
    2. The result will be something like 98.3 or 104.6 or 35.4 rather than just 35 or 45 or 198? Is this correct?
    Chris
    New Jersey
    I forgot to mention, maybe I can buy a PIC with 2 USART ports and could solve the problem also.
    Hi Chris,
    You won't need a PIC with a hardware USART, and you can use any I/O-pin or
    serial command you prefer. I just used the USART since I had a board with a
    hardware serial connection for the test.
    -Bruce
    tech at rentron.com
  1. Reading in Manchester code
    By brid0030 in forum Code Examples
    Last Post: - 10th March 2009, 22:55
  2. How much code space do PBP statements use.
    Last Post: - 13th February 2009, 22:31
  5. Re-Writing IF-THEN-AND-ENDIF code?
    Last Post: - 18th August 2006, 18:23
