Array data being corrupted
Results 1 to 2 of 2
    caverman's Avatar
    caverman Guest
    Unhappy Array data being corrupted
    If I use the following:
    TR var word[7] 'trim
    G var byte[7] 'gain
    R var bit[7] 'reverse
    C var byte[7] 'center
    AD var bit[7] '0=Ana, 1=Digital
    LM var byte[7] 'left max measured from 0. Is <RM
    RM var byte[7] 'right max measured from 0. Is >LM
    'hard coded S5 var byte[8] 'Channel 5, 8 states 0->255, gets *4 for uS
    'hard coded S6 var byte[8] 'Channel 6, 8 states 0->255, gets *4 for uS
    DB var byte[7] 'deadband around center value -> no servo change
    arrayPVal var word[7]
    I find that TR[0] gets strange (corrupted) data in it TR[1] data is OK
    TR[0] also get zonked if I move its line to the end after arrayPVal.
    Now if I use
    TR var word[8] 'trim
    G var byte[8] 'gain
    R var bit[8] 'reverse
    C var byte[8] 'center
    AD var bit[8] '0=Ana, 1=Digital
    LM var byte[8] 'left max measured from 0. Is <RM
    RM var byte[8] 'right max measured from 0. Is >LM
    DB var byte[8] 'deadband around center value -> no servo change
    arrayPVal var word[8]
    it all seems to work OK
    Any thoughts on why. Sure words and things need to be alinged in memory
    but I would have though PICBasic Pro would have sorted that out for me.
    If you compile nothing but your variables, you'll see that PBP creates arrayPVal var word[7] first, followed immediately by TR var word[7].
    If your code does something like arrayPVal[7] = 10, then you're writing outside the bounds of your array arrayPVal, and accessing TR[0].
    PBP does not perform bounds checking when accessing arrays.
    arrayPVal var word[7] ' = arrayPVal[0] to arrayPVal[6]
    TR var word[7] ' = TR[0] to TR[6]
    With PBP allocating RAM for arrayPVal followed immediately by TR, then arrayPVal[7] = 0 will actually clear TR[0]. You will not get an error at compile time, but you will not be working on the array element you think you are.
    I.E. you would then be corrupting the low byte in TR[0], which would simulate your problem.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
  1. Using Nokia LCD
    Last Post: - 3rd May 2018, 04:47
  2. Read/Write Problem
    Last Post: - 10th February 2010, 01:51
  3. Big characters on HD44780 4x20
    Last Post: - 7th January 2007, 02:21
  4. LCD + bar graph
    Last Post: - 5th October 2005, 14:50
  5. Sinus calculating !
    Last Post: - 28th November 2004, 23:56
