Tris Register use.
Results 1 to 8 of 8
    Oct 2006
    Default Tris Register use.
    I am new to the forum and trying to interface a 16F877 to a GE 90-30 PLC with Shiftin/out. My first question as I start this, is this. I have read in the past in the data sheet I think that to be compatible with future versions of the PIC that we are not supposed to use the Tris command. Could someone verify this for me and tell me what I am supposed to do in its place. Sorry about the previous post to the FAQ, this is my firs post.
    Oct 2006
    Default Found the statement in the data sheet.
    It reads, Note: To maintain upward compatibility with future PIC16F87XA products, do not use the OPTION and TRIS instructions. So the question, what do I use in place of the TRIS instruction?
    Feb 2003
    Salt Lake City, Utah USA
    Smile
    The TRIS Command in question is an assembly level command and not a PBP command.
    With the 877, if you write “TRISA=7”, for example, you are not using the TRIS command but loading the TRISA register directly. PBP takes care of all these issue for you so no worries.
    ASM Equivalent of what TRISA=7 does
    MOVLW 007h
    MOVWF TRISA
    ASM Equivalent using TRIS command - PBP does not do this (and this may not be supported on the 877?)
    MOVLW 007h
    TRIS PORTA
    Paul Borgmeier
    Salt Lake City, UT
    USA
    __________________
    Oct 2006
    Thanks for clearing that up for me!!
    Jan 2006
    Istanbul
    I did not hear that and can not confirm.
    But, since we are in PBP forum, you can use INPUT and/or OUTPUT commands to do what TRIS does.
    Example:
    TRISA.1 = 1
    'make PORTA.1 an input pin.
    same as
    INPUT PORTA.1
    'Make PORTA.1 an input pin.
    or
    TRISE.2 = 0
    'Make PORTE.2 an output pin.
    same as
    OUTPUT PORTE.2
    Feb 2003
    Smile
    Just for completeness, it appears the TRIS assembly command works on the 16F877 for PORTS A,B, and C, but not PORTS D or E.
    Thr following works but gives warning "Use of this instruction is not recommended"
        movlw   0x07
        TRIS   PORTA
    and this
        movlw   0x07
        TRIS   PORTD
    gives errors.
    Paul Borgmeier
    Salt Lake City, UT
    USA
    __________________
    Jul 2005
    From PIC16F87X Data Sheet DS30292C-page 135, section 13.0 INSTRUCTION SET SUMMARY
    future PIC16F87X products, do not use the
    Patient: Doctor, it hurts when I do this.
    Doctor: Then don’t do that!
    TRISA= {value}
    TRISB= {value}
    TRISC= {value}
    TRISD= {value}
    TRISE= {value}
    Are all valid PBP statements and may/should be used to set TRIS directly (as they will take care of any required bank setting, ect).
    if you really want to use ASM in PBP, and don't want to look where TRIS or else register is located...
    asm
        CHK?RP TRISA ; PBP BANK switching macro
        movlw d'7'
        movwf TRISA
    endasm
  1. Active low input?
    By CosMecc in forum mel PIC BASIC Pro
    Last Post: - 8th August 2010, 20:31
  2. Can anyone help a newcomer?
    By scopit in forum Schematics
    Last Post: - 20th October 2009, 09:23
  3. PIC16F877A pwm use for IR transmission
    By mcbeasleyjr in forum General
    Last Post: - 11th July 2009, 18:51
  4. Another RTC, DS1287
    Last Post: - 12th December 2006, 17:07
  5. MX7705 or AD7705 experience
    By FM11 in forum mel PIC BASIC Pro
    Last Post: - 12th January 2006, 21:54
