SEROUT2 takes 1400ms to execute?
Results 1 to 5 of 5
    Nov 2004
    Calabasas, CA
    Default SEROUT2 takes 1400ms to execute?
    SerOut2 PORTB.6,N2400,["A",w2]
    I've timed this on a tight loop and it takes almost 1500ms to execute! Whats taking so long? How can I speed this up to us? Is the "A" just for a handshake? I just copied it from the manual. No define or anything needed to use it?
    The compiler is set to XT and both PIC's have 3.58 oscillators and program defines osc 3.
    James
    droptail, The statement will "WAIT" for an ascii "A" to be received before looking for the variable. I don't see any timeout so what it taking so long is the receiving of the ascii "A" which is coming from some external device.
    Nov 2004
    Calabasas, CA
    Default clarification of qualifier & external device please
    master PIC: SerOut2 PORTB.6,N2400,["A",w2]
    slave PIC: SerIn2 PORTB.0,N2400,[wait ("A"),w2]
    Not sure if I understand completely. The delay has been determined @ SEROUT2 statement, no external devise is part of this, not waiting at the SERIN2 statement. I have included the modifier "wait" and qualifier "A" for timing purposes to transmit byte w2, a marker if you will. This qualifier "A" isn't anywhere else in the program, I assumed it is generated at the time of the Serout2 statement execution (instantly). Actually, I need to know if using the qualifier "A" in SEROUT is OK, I can't find any reference to it in the manual in SEROUT or SEROUT2, but I believe it is necessary to send if SERIN is expecting to see it? Why the long delay in transmittal? Need I establish the use of the qualifier elsewhere first?
    James
    droptail, I spoke incorrectly. At first glance I thought you were receiving the string but after comming back to the message I noticed that you were sending the command. There is no reason for the pic to wait before sending the string "A",w2. I only ask is the variable w2 a word or a byte? Next time I will read the post twice before replying. Sorry.
    Nov 2004
    Calabasas, CA
    W2 can be a word. After some comparison I found that SEROUT2 takes 735ms to execute while SEROUT takes some us long. Aren't using the flowpin option so don't need SEROUT2. Am satisfied with the results. Still wanted to understand the source and role of the qualifier "A".
    James
  1. Serout and 18F87J50
    By Glenn_Webber in forum Serial
    Last Post: - 20th November 2009, 14:26
  2. Serout to serial servo
    By azmax100 in forum mel PIC BASIC Pro
    Last Post: - 12th August 2009, 16:46
  3. SLOW Serin2 and Serout2
    By dragons_fire in forum General
    Last Post: - 26th June 2009, 02:38
  4. Gps with 16f628
    By dragons_fire in forum mel PIC BASIC Pro
    Last Post: - 8th June 2006, 03:38
  5. TMR1 interrupt question
    By ronjodu in forum mel PIC BASIC Pro
    Last Post: - 15th February 2006, 03:02
