PCLATH initialising for Bootloader
Results 1 to 9 of 9
    Oct 2003
    Australia
    Unhappy PCLATH initialising for Bootloader
    Hi there,
    It's been a while since I played here and I'm a bit rusty...
    A while ago I was loading tiny bootloader into the 16F88 and it was working but now, I cant figure what the heck I'm doing wrong, my program wont install using the bootloader, I get a error come up:
    WARNING: PCLATH not initialised before GOTO! ... could not repair.,
    Maybe you sould use some directive in your compiler to enable the use of bootloaders
    The tiny website recommends that the program must meet this requirement:
    it must have in the first 4 words of memory a GOTO to the start of the main program. (this is what the majority of the bootloaders require). So in assembler it should look something like this:
    asm
    org 0
    ;clrf STATUS
    clrf PCLATH
    goto Main
    endasm
    This codedoesnt make a lot of sense to me but perhaps there is somebody out there that can point me in the right direction.
    BTW What the heck does LATH in PCLATH stand for???
    Oh yeah, I use MCS and PICBASIC pro for compilying.. dur!
    Cheers
    J
    Out of curiosity, Did you insert DEFINE LOADER_USED 1 at the top of your code?
    Oct 2003
    Australia
    A Ha!,
    I think that did the trick... btw, any idea about that LATH comment I made?
    Thanks Steve.
    J
    PCLATH = (program counter latch high) = the latch register you write to that
    holds the value to be loaded into PCH.
    PCH is the high 5-bits of the 13-bit program counter for the 14-bit core. PCL
    is the lower 8-bits.
    You can't write directly to PCH, so you write to PCLATH. The value you place
    in PCLATH gets latched into the program counter high (PCH) when PCL is
    written.
    All 13-bits of the program counter have to be written simultaneously. That's
    the purpose of the PCLATH latch register.
    The error you're getting is because you haven't reserved enough space in the
    beginning or program memory for the Tiny loader to automatically insert the
    CLRF PCLATH instruction.
    On return from the loader sub routine PCH needs to be cleared to point to the
    program memory in bank 0 where your code is located.
    If CLRF PCLATH can't be inserted before GOTO Main, then it would jump back
    to program memory in bank 1 instead of bank 0 causing major problems.
    As Steve mentioned, inserting DEFINE LOADER_USED 1 takes care of this since
    it tells PBP to reserve the first 4 locations for loader use.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Oct 2003
    Australia
    Talking
    Thats a great reply, thanks Bruce!
    J
    Apr 2005
    I'm having a similar problem using the tinybootloader, but when I use microcode studio's bootloader I don't have any issues.
    When using the tiny loader the first time I bootload my program to the chip it works, but I get the following error in the Tinybootloader window:
    HEX: 9 hours old, INHX32,16Fcode+cfg+eeprom , total=14546 bytes.
    Searching for PIC ...
    Found:16F 876A/877A
    WARNING: PCLATH not initialised before GOTO! ... sucessfully repaired.,
    WRITE OK. time:9.203 sec
    The problem I am having is I can't bootload a new hex file to the chip after this, everytime I try I get the following error:
    pic sending unknown data: "K" <> E0h=à
    Check baudrate & Start Write while PIC is not sending serial data (e.g. in reset)
    ERROR!
    I would appreciate any advice you may have.
  1. Is this code not initialising the LCD properly?
    By Platypus in forum mel PIC BASIC Pro
    Last Post: - 30th January 2010, 20:14
  2. 16f877a: PCLATH register
    By herve in forum mel PIC BASIC
    Last Post: - 6th September 2006, 07:03
  3. Replies: 1
    Last Post: - 6th September 2005, 17:32
