Nope, you still missed that cigar... but you're close...
StorePage var word
StartAddress var Word
StoreData:
StartAddress=StorePage*64
I2CWRITE SDA,SCL,EE_addr,StartAddress,[str data1\64]
Consider the above subroutine. Before it is called, you set the Page Number that you wish to store your 64 bytes of data into. Since you wish only to store 3 pages, the variable StorePage can be 0, 1 or 2, but in fact for the 24LC256 can be any number between 0 and 511 (max 512 pages as you said).
The first line takes the Page number and converts it to a linear address pointer, so that for example, if your Page is zero, the address will point to zero. Page=1 then Address=64. Page=2 then Address=128 and so on...
The I2CWRITE line will save 64 bytes in one hit from your array data1 (providing your EE_addr is set correctly).
That's it... all there is to it.
To read back, just preset your StorePage accordingly and create a similar ReadData subroutine using I2CREAD...
Melanie
