Interupts and Command string
Results 1 to 14 of 14
    I remind that code...You remove my name on the top header
    Well why not simply use HSERIN in the USARTInterrupt section?
    Feb 2005
    Essex, UK
    Your quite correct Steve, it was your code which i found at http://www.picbasic.co.uk/forum/show...6F877+%4020MHZ
    I didn't remove any of your signatures from the top header as they weren't on the code i found as above. All credits recognised though ;-).
    Would you be kind enough to give an example of what you mean using the HSERIN command.
    As in the interrupt code you are disabling the serial port first. Are you saying remove these lines, and then treat it with just the HSERIN command.
    I am new to serial comms and often learn better from a quick example (if you could oblidge).
    Many thanks,
    Yup that's what i think... just an idea.
    So you already figured something like
    Disable
    USARTInterrupt:
        HSERIN [Data1, Data2,....]
        '    Data processing or not here
        Resume
    Enable
    Just read the HSERIN section. You may also use STR modifier too. Dpending what kind of data format you'll use.
    Feb 2005
    Essex, UK
    Excellent help, thanks.
    I have now managed to get variables sent from VB to PIC.
    The code now looks like this:
    Start:
        '    Main program loop that make the user happy to
        '    see a LED flashing to mean that something is
        '    running
        Hserout [hours, minutes, seconds]
        toggle userled
        for delay = 1 to 5000       ' use a loop delay to ensure
          pauseus 5                 ' getting interrupt as fast as
          next                      ' possible
        goto start
    disable interrupt
    USARTInterrupt:
        '    Here's the interrupt routine who will make the user
        HSERIN [hours, minutes, seconds]
        Write 5, hours
        Write 6, minutes
        Write 7, seconds
        resume                      ' get out of here
    enable interrupt
    However, i can only send over single numerals, ie 0-9. But in the timing functions for Hrs, Mins and Sec it could be upto 59. How do i get the PIC to reconise the double figures. If i try to send them the PIC just hangs.
    The write command is to just store the variables in EEPROM for later use.
    Thanks for your help,
    Suppose the actual time is 1:33:56
    Send it as 013356
    actual time is 1:02:01
    send it as 010201
    THEN you use the DEC2 modifier
    HSERIN [DEC2 hour, DEC2 Minute, DEC2 Second]
    Feb 2005
    Essex, UK
    Yup, that worked very well. I'm trying to figure out the methods of sending and receiveing data on 2 languages, PIC and VB.
    I managed to get the combining of the timings and it now it reads and outputs very well. Thank you Steve.
    I've been reading about qualifiers, but can only see the WAIT command, where as i'm using an interupt, this isn't really what i want.
    I want to look for a command sent from VB to signal what routine to jump too. For example in the interupt if the word TIMINGS is received then it reads and stores the subsequent timing variables. But if the word FLAGS is received then it stores the flag variables etc etc.
    In VB i would output something like
    MSComm1.Output = "Time" & Format(Hours, "00") & Format(Minutes, "00") & Format(Seconds, "00") & Format(SuSeconds, "00")
    Is this possible?
    As at the moment it will just deal with the 8 numbers it receives, i want it to be more choosy depending what VB sends accross.
    Many thanks,
    for the HSERIN modifier refer to SERIN2
    about VB, here's a quote from VB6 Black book pdf
